주요 콘텐츠로 건너뛰기
How to Install Handlebar Tape
필요한 것
  1. How to Install Handlebar Tape, How to Install Handlebar Tape: 1 단계, 이미지 2개 중 1개 How to Install Handlebar Tape, How to Install Handlebar Tape: 1 단계, 이미지 2개 중 2개
    • Flip the hood of the brake lever upwards.
  2. How to Install Handlebar Tape: 2 단계, 이미지 3개 중 1개 How to Install Handlebar Tape: 2 단계, 이미지 3개 중 2개 How to Install Handlebar Tape: 2 단계, 이미지 3개 중 3개
    • Peel off the adhesive covering from the back of the bar tape.
    • Place one end of the bar tape around the handlebar, making sure to leave a half inch extended past the end of the handlebar.
    • Begin tightly wrapping the bar tape clockwise around the handlebar so that the bar tape overlaps itself slightly.
  3. How to Install Handlebar Tape: 3 단계, 이미지 2개 중 1개 How to Install Handlebar Tape: 3 단계, 이미지 2개 중 2개
    • After a few wraps, tuck the extra bar tape into the end of the handlebar and firmly push in the bar end plug.
  4. How to Install Handlebar Tape: 4 단계, 이미지 2개 중 1개 How to Install Handlebar Tape: 4 단계, 이미지 2개 중 2개
    • Continue to tightly wrap the bar tape around the bar as evenly as possible.
    • Make sure the adhesive on the back of the bar tape is making contact with the metal handlebar.
  5. How to Install Handlebar Tape: 5 단계, 이미지 3개 중 1개 How to Install Handlebar Tape: 5 단계, 이미지 3개 중 2개 How to Install Handlebar Tape: 5 단계, 이미지 3개 중 3개
    • Take the extra piece of bar tape provided and cut it to fit the back of the brake lever.
  6. How to Install Handlebar Tape: 6 단계, 이미지 3개 중 1개 How to Install Handlebar Tape: 6 단계, 이미지 3개 중 2개 How to Install Handlebar Tape: 6 단계, 이미지 3개 중 3개
    • Continue wrapping over lever.
    • Keep in mind the tightness and evenness of space between each wrap as you continue.
  7. How to Install Handlebar Tape: 7 단계, 이미지 2개 중 1개 How to Install Handlebar Tape: 7 단계, 이미지 2개 중 2개
    • Flip the break lever hood back down and continue.
  8. How to Install Handlebar Tape: 8 단계, 이미지 2개 중 1개 How to Install Handlebar Tape: 8 단계, 이미지 2개 중 2개
    • Stop wrapping about 2 inches from stem.
  9. How to Install Handlebar Tape: 9 단계, 이미지 3개 중 1개 How to Install Handlebar Tape: 9 단계, 이미지 3개 중 2개 How to Install Handlebar Tape: 9 단계, 이미지 3개 중 3개
    • Cut the bar tape diagonally at an approximately 60 degree angle.
  10. How to Install Handlebar Tape: 10 단계, 이미지 1개 중 1개
    • Finish the wrap.
    • The cut should make the end of the bar tape a straight line.
  11. How to Install Handlebar Tape: 11 단계, 이미지 3개 중 1개 How to Install Handlebar Tape: 11 단계, 이미지 3개 중 2개 How to Install Handlebar Tape: 11 단계, 이미지 3개 중 3개
    • Use the electrical tape provided to tightly secure the end of the wrap.
  12. How to Install Handlebar Tape: 12 단계, 이미지 3개 중 1개 How to Install Handlebar Tape: 12 단계, 이미지 3개 중 2개 How to Install Handlebar Tape: 12 단계, 이미지 3개 중 3개
    • Press down on electrical tape to secure it.
  13. How to Install Handlebar Tape: 13 단계, 이미지 3개 중 1개 How to Install Handlebar Tape: 13 단계, 이미지 3개 중 2개 How to Install Handlebar Tape: 13 단계, 이미지 3개 중 3개
    • Repeat steps 1-12 on the other side, now wrapping counterclockwise.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Elizabeth Hall
회원 가입일: 04/28/17
131 평판
안내서 1개를 작성함
UC Davis, Team S2-G7, Cole Spring 2017 UC Davis, Team S2-G7, Cole Spring 2017 회원
UCD-COLE-S17S2G7
3 회원들
안내서 1개 작성
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 13
전체 시간: 4,284
