주요 콘텐츠로 건너뛰기
How to Install Shoulder Buttons in Your Game Boy Advance SP
  1. How to Install Shoulder Buttons in Your Game Boy Advance SP, Install the hinge pin: 1 단계, 이미지 2개 중 1개 How to Install Shoulder Buttons in Your Game Boy Advance SP, Install the hinge pin: 1 단계, 이미지 2개 중 2개
    • If the hinge pin fell out when removing the shoulder button, put it back into place.
  2. How to Install Shoulder Buttons in Your Game Boy Advance SP, Install the spring: 2 단계, 이미지 3개 중 1개 How to Install Shoulder Buttons in Your Game Boy Advance SP, Install the spring: 2 단계, 이미지 3개 중 2개 How to Install Shoulder Buttons in Your Game Boy Advance SP, Install the spring: 2 단계, 이미지 3개 중 3개
    • The two springs are not interchangeable. It should be clear if you're trying to install the wrong spring, as it won't fit correctly in the button.
    • Slide the spring into the shoulder button so the bent arm goes into the cutout on the inside edge.
  3. How to Install Shoulder Buttons in Your Game Boy Advance SP, Put the shoulder button in place: 3 단계, 이미지 3개 중 1개 How to Install Shoulder Buttons in Your Game Boy Advance SP, Put the shoulder button in place: 3 단계, 이미지 3개 중 2개 How to Install Shoulder Buttons in Your Game Boy Advance SP, Put the shoulder button in place: 3 단계, 이미지 3개 중 3개
    • When installing the button, make sure it's oriented so the spring's straight arm is on top.
    • Use your fingers to hold the spring in place and slide the button over the hinge pin and into its recess.
  4. How to Install Shoulder Buttons in Your Game Boy Advance SP, Push the spring arm into place: 4 단계, 이미지 2개 중 1개 How to Install Shoulder Buttons in Your Game Boy Advance SP, Push the spring arm into place: 4 단계, 이미지 2개 중 2개
    • Use your finger, a spudger, or a pair of tweezers to rotate the spring arm into its clip.
  5. How to Install Shoulder Buttons in Your Game Boy Advance SP, Install the other shoulder button: 5 단계, 이미지 3개 중 1개 How to Install Shoulder Buttons in Your Game Boy Advance SP, Install the other shoulder button: 5 단계, 이미지 3개 중 2개 How to Install Shoulder Buttons in Your Game Boy Advance SP, Install the other shoulder button: 5 단계, 이미지 3개 중 3개
    • Repeat the process to install the other shoulder button.
결론
Return to your original repair guide and continue with reassembly.
작성자
1다른 기여자 명과 함께
Spencer Day
회원 가입일: 09/14/22
155,036 평판
안내서 1,033개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 23
지난 30일: 105
전체 시간: 337
