주요 콘텐츠로 건너뛰기
How to Install a Fifth String Shubb Banjo Capo
필요한 것
  1. How to Install a Fifth String Shubb Banjo Capo, How to Install a Fifth String Shubb Banjo Capo: 1 단계, 이미지 3개 중 1개 How to Install a Fifth String Shubb Banjo Capo, How to Install a Fifth String Shubb Banjo Capo: 1 단계, 이미지 3개 중 2개 How to Install a Fifth String Shubb Banjo Capo, How to Install a Fifth String Shubb Banjo Capo: 1 단계, 이미지 3개 중 3개
    • Line the capo up along the fifth string side of the fretboard as shown.
    • Line the capo screw holes up about 12 mm from the fifth fret bar and about 4 mm from the face of the fret.
    • Be careful not to line the capo screw holes up directly below a fret bar or directly on top of a fret marker.
  2. How to Install a Fifth String Shubb Banjo Capo: 2 단계, 이미지 1개 중 1개
    • Use the marker to mark where the screws should go.
  3. How to Install a Fifth String Shubb Banjo Capo: 3 단계, 이미지 1개 중 1개
    • Use the drill to drill both holes for the two screws.
    • The holes should be drilled about 1 cm deep
    • You may need to borrow an extra pair of hands to help you stabilize the banjo while you perform this step.
  4. How to Install a Fifth String Shubb Banjo Capo: 4 단계, 이미지 2개 중 1개 How to Install a Fifth String Shubb Banjo Capo: 4 단계, 이미지 2개 중 2개
    • Use the flat head screw driver to insert and tighten the screws.
  5. How to Install a Fifth String Shubb Banjo Capo: 5 단계, 이미지 3개 중 1개 How to Install a Fifth String Shubb Banjo Capo: 5 단계, 이미지 3개 중 2개 How to Install a Fifth String Shubb Banjo Capo: 5 단계, 이미지 3개 중 3개
    • To use the capo, slide the capo finger down to the desired fret.
    • Then, tighten the spring knob.
결론
For more information check out the Shubb fifth string capo website at: http://www.shubb.com/fs/index.html
다른 6명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Sara Wier
회원 가입일: 02/24/15
263 평판
안내서 1개를 작성함
Cal Poly, Team 23-4, Green Winter 2015 Cal Poly, Team 23-4, Green Winter 2015 회원
CPSU-GREEN-W15S23G4
7 회원들
안내서 15개를 작성함
1가이드 댓글
thank you. Now, I know how to do and i décide to buy a shubb and to install it
Jean-Denis Del - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 42
전체 시간: 7,886
