소개
This guide will walk you through the quick and simple process of assembling a Mac Pro First Generation Hard Drive Sled Adapter. The existing hard drive bay sled brackets in this device are meant to fit 3.5" hard drives, but this adapter enables you to install any SATA 2.5" solid state, hybrid, or standard hard drive. It also correctly aligns the SATA connector to match the socket in your Mac Pro.
  1. Insert the two tabs on the left side of the metal adapter bracket into the slots on the left side of the hard drive bay sled. Align the holes on the right side. Align the holes on the right side.
    • Insert the two tabs on the left side of the metal adapter bracket into the slots on the left side of the hard drive bay sled.
    • Align the holes on the right side.
  2. Screw the two 7.8mm PH0 screws into the two holes on the right.
    • Screw the two 7.8mm PH0 screws into the two holes on the right.
    • Leave these screws slightly loose; they will be tightened once the hard drive is attached.
  3. 아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
    아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
  4. Align the holes in the hard drive with the three holes on the bracket. Screw the three 6.1mm PH0 screws into the bracket and hard drive. These screws can be secured tightly.
    • Align the holes in the hard drive with the three holes on the bracket.
    • Screw the three 6.1mm PH0 screws into the bracket and hard drive.
    • These screws can be secured tightly.
  5. Tighten the two 7.8mm PH0 screws on the right side of the bracket.
    • Tighten the two 7.8mm PH0 screws on the right side of the bracket.
결승점
Kristen Gismondi
회원 가입일: 2014년 11월 12일
21,628 평판
안내서 9개 작성하였습니다
iFixit iFixit 회원
Community
101 회원들
안내서 8,660개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 41
