주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
How to Install a Hard Drive Sled Adapter for Mac Pro First Generation
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. How to Install a Hard Drive Sled Adapter for Mac Pro First Generation, How to Install a Hard Drive Sled Adapter for Mac Pro First Generation: 1 단계, 이미지 1/3 How to Install a Hard Drive Sled Adapter for Mac Pro First Generation, How to Install a Hard Drive Sled Adapter for Mac Pro First Generation: 1 단계, 이미지 2/3 How to Install a Hard Drive Sled Adapter for Mac Pro First Generation, How to Install a Hard Drive Sled Adapter for Mac Pro First Generation: 1 단계, 이미지 3/3
    • Insert the two tabs on the left side of the metal adapter bracket into the slots on the left side of the hard drive bay sled.
    • Align the holes on the right side.
  2. How to Install a Hard Drive Sled Adapter for Mac Pro First Generation: 2 단계, 이미지 1/1
    • Screw the two 7.8mm PH0 screws into the two holes on the right.
    • Leave these screws slightly loose; they will be tightened once the hard drive is attached.
  3. How to Install a Hard Drive Sled Adapter for Mac Pro First Generation: 3 단계, 이미지 1/3 How to Install a Hard Drive Sled Adapter for Mac Pro First Generation: 3 단계, 이미지 2/3 How to Install a Hard Drive Sled Adapter for Mac Pro First Generation: 3 단계, 이미지 3/3
    • Align the holes in the hard drive with the three holes on the bracket.
    • Screw the three 6.1mm PH0 screws into the bracket and hard drive.
    • These screws can be secured tightly.
  4. How to Install a Hard Drive Sled Adapter for Mac Pro First Generation: 4 단계, 이미지 1/1
    • Tighten the two 7.8mm PH0 screws on the right side of the bracket.
결승점
Kristen Gismondi
회원 가입일: 11/12/14
81,833 평판
안내서 200개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 64
