주요 콘텐츠로 건너뛰기
How to Install a Heatsink on an M.2 SSD
필요한 것
  1. How to Install a Heatsink on an M.2 SSD, Prepare the first thermal pad: 1 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • The heatsink uses thermal pads to dissipate heat from either side of the blade SSD. The thermal pads may come with plastic liners on each side, so make sure all are removed before use.
    • Use a pair of tweezers to peel one side of protective film away from one of the thermal pads.
  2. How to Install a Heatsink on an M.2 SSD, Install the first thermal pad: 2 단계, 이미지 3개 중 1개 How to Install a Heatsink on an M.2 SSD, Install the first thermal pad: 2 단계, 이미지 3개 중 2개 How to Install a Heatsink on an M.2 SSD, Install the first thermal pad: 2 단계, 이미지 3개 중 3개
    • Align the exposed side of the thermal pad with the bottom tray section of the heatsink assembly.
    • Lay the thermal pad down so it covers the tray evenly.
    • Use your finger to lightly press down on the thermal pad to adhere it to the surface.
  3. How to Install a Heatsink on an M.2 SSD, Prepare the second thermal pad: 3 단계, 이미지 1개 중 1개
    • Use a pair of tweezers to peel one side of protective film away from the remaining thermal pad.
  4. How to Install a Heatsink on an M.2 SSD, Install the second thermal pad: 4 단계, 이미지 3개 중 1개 How to Install a Heatsink on an M.2 SSD, Install the second thermal pad: 4 단계, 이미지 3개 중 2개 How to Install a Heatsink on an M.2 SSD, Install the second thermal pad: 4 단계, 이미지 3개 중 3개
    • Align the exposed side of the thermal pad with the top section of the heatsink.
    • Lay the thermal pad down so it covers the top section evenly.
  5. How to Install a Heatsink on an M.2 SSD, Remove the bottom thermal pad liner: 5 단계, 이미지 1개 중 1개
    • Use a pair of tweezers to remove the plastic liner from the thermal pad in the tray.
    • The thermal pad might lift up from the tray as the liner is removed—this is normal. Use your finger to keep the pad in the tray.
  6. How to Install a Heatsink on an M.2 SSD, Lay the SSD in the tray: 6 단계, 이미지 3개 중 1개 How to Install a Heatsink on an M.2 SSD, Lay the SSD in the tray: 6 단계, 이미지 3개 중 2개 How to Install a Heatsink on an M.2 SSD, Lay the SSD in the tray: 6 단계, 이미지 3개 중 3개
    • Lay the M.2 SSD into the tray, the side with the most chips facing up.
    • Make sure the SSD is centered in the tray. The tray shouldn't cover the contacts or the screw cutout.
  7. How to Install a Heatsink on an M.2 SSD, Remove the top thermal pad liner: 7 단계, 이미지 1개 중 1개
    • Use a pair of tweezers to remove the plastic liner from the thermal pad on the heatsink's top section.
    • The thermal pad might lift up from the heatsink as the liner is removed—this is normal. Use your finger to keep the pad in place.
  8. How to Install a Heatsink on an M.2 SSD, Snap the heatsink in place: 8 단계, 이미지 3개 중 1개 How to Install a Heatsink on an M.2 SSD, Snap the heatsink in place: 8 단계, 이미지 3개 중 2개 How to Install a Heatsink on an M.2 SSD, Snap the heatsink in place: 8 단계, 이미지 3개 중 3개
    • Align the top heatsink section over the SSD and the tray.
    • Firmly press the two halves together. You'll feel it "snap" into place.
  9. How to Install a Heatsink on an M.2 SSD, Check the alignment: 9 단계, 이미지 1개 중 1개
    • For the SSD to fit in a desktop PC or a PlayStation 5, the heatsink needs to be centered on the SSD.
    • Make sure that the heatsink is close to the screw cutout but doesn't overhang it.
    • If you're having trouble installing your SSD, you may have to slightly adjust the heatsink's position.
    • Use your fingers to slide the SSD between the two halves of the heatsink assembly until fitment is just right.
결론
Installation didn’t go as planned? Check out our Computer Hardware Answers community or PlayStation 5 Answers community for troubleshooting help.
다른 8명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Carsten Frauenheim
회원 가입일: 03/10/20
155,914 평판
안내서 439개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,758개를 작성함
4가이드 댓글
If your SSD has a big "warranty void if removed" sticker over the chips, do you have to remove it? Or can you stick the thermal pad over that sticker?
shamino - 답글
You can leave the sticker on the SSD! Just make sure to remove any adhesive liners on the thermal pad.
Carsten Frauenheim -
I just bought predator gm7000 ssd with heatsink. The ssd only come with one thermal pad on top to be use with the heatsink. Do i need to get another thermal pad for bottom?
afiqtobi9 - 답글
This is just a generic guide, so not every step applies to every situation. I've checked your mentioned SSD and it comes with a custom heatsink for it, which means you don't need another one. Thermal pads only help if they're touching a surface (i.e. a metal sheet) for heat transfer. Since this isn't how yours is build/installed, a second pad would be basically pointless. Hope this helps :)
Kongoduff -
댓글 쓰기
조회 통계:
지난 24시간: 91
지난 7일: 561
지난 30일: 2,562
전체 시간: 95,282
