주요 콘텐츠로 건너뛰기
How to Install an M.2 SSD
필요한 것
  1. How to Install an M.2 SSD, Reposition the standoff: 1 단계, 이미지 2개 중 1개 How to Install an M.2 SSD, Reposition the standoff: 1 단계, 이미지 2개 중 2개
    • If your laptop did not include a removable standoff or only supports one M.2 SSD form factor, you can skip this step.
    • Use a screwdriver to remove the preinstalled standoff.
    • If your laptop does not include a preinstalled standoff, you will need to get one.
    • Find the correct standoff location that corresponds to your desired M.2 SSD form factor.
    • Screw in the standoff.
  2. How to Install an M.2 SSD, Insert the SSD: 2 단계, 이미지 3개 중 1개 How to Install an M.2 SSD, Insert the SSD: 2 단계, 이미지 3개 중 2개 How to Install an M.2 SSD, Insert the SSD: 2 단계, 이미지 3개 중 3개
    • Grip the SSD on the sides near the screw indent.
    • Gently slide the SSD into the socket at about a 30˚ angle.
    • The socket is spring loaded and will support the SSD at an angle.
  3. How to Install an M.2 SSD, Screw down the SSD: 3 단계, 이미지 3개 중 1개 How to Install an M.2 SSD, Screw down the SSD: 3 단계, 이미지 3개 중 2개 How to Install an M.2 SSD, Screw down the SSD: 3 단계, 이미지 3개 중 3개
    • Use your finger to hold the SSD down horizontally, making sure that the screw indent aligns with the standoff.
    • Screw down the SSD to secure it.
  4. How to Install an M.2 SSD, Apply a thermal pad: 4 단계, 이미지 3개 중 1개 How to Install an M.2 SSD, Apply a thermal pad: 4 단계, 이미지 3개 중 2개 How to Install an M.2 SSD, Apply a thermal pad: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • If your laptop did not have a thermal pad installed, you can skip this step.
    • Use tweezers or your fingers to place a thermal pad on the top of the SSD.
    • The original thermal pad can be reused if it is clean and undamaged.
결론
Installation didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
다른 16명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Chayton Ritter
회원 가입일: 08/21/20
24,883 평판
안내서 105개를 작성함
2가이드 댓글
muchas gracias por la ayuda amigo dios t bendiga
Jose Percy Castro Carrera - 답글
شكرا على المعلومات موقع رائع
tayeb - 답글
댓글 쓰기
조회 통계:
지난 24시간: 10
지난 7일: 87
지난 30일: 427
전체 시간: 10,197
