주요 콘텐츠로 건너뛰기
How to Install and Remove Expansion Cards
필요한 것
  1. How to Install and Remove Expansion Cards, Set your laptop down: 1 단계, 이미지 1개 중 1개
    • Set your laptop face-down on a clean work surface.
  2. How to Install and Remove Expansion Cards, Install an Expansion Card: 2 단계, 이미지 3개 중 1개 How to Install and Remove Expansion Cards, Install an Expansion Card: 2 단계, 이미지 3개 중 2개 How to Install and Remove Expansion Cards, Install an Expansion Card: 2 단계, 이미지 3개 중 3개
    • The next two steps show how to install an Expansion Card.
    • Slide an Expansion Card into an Expansion Card slot.
    • You don't need to unlock the latches to install the Expansion Cards—only when you want to remove them.
    • The Expansion Cards should click into place, and the front edge should be flush with the laptop.
  3. How to Install and Remove Expansion Cards: 3 단계, 이미지 2개 중 1개 How to Install and Remove Expansion Cards: 3 단계, 이미지 2개 중 2개
    • If there's a red bar showing under the Expansion Card latch, use your finger to flip the latch and lock the Expansion Card into its slot.
    • Locking the Expansion Card slots helps keep the cards in place when you unplug cables from them.
  4. How to Install and Remove Expansion Cards, Remove an Expansion Card: 4 단계, 이미지 2개 중 1개 How to Install and Remove Expansion Cards, Remove an Expansion Card: 4 단계, 이미지 2개 중 2개
    • The next two steps show how to remove an Expansion Card.
    • Use your fingers to flip the two Expansion Card latches (one for each side) into the unlocked position.
    • The latches display a red bar when they're unlocked.
  5. How to Install and Remove Expansion Cards: 5 단계, 이미지 3개 중 1개 How to Install and Remove Expansion Cards: 5 단계, 이미지 3개 중 2개 How to Install and Remove Expansion Cards: 5 단계, 이미지 3개 중 3개
    • Grip the lip of the Expansion Card with your fingers.
    • Pull the Expansion Card out of its slot and remove it.
    • If you have trouble pulling the Expansion Card out, you can also use the flat end of your Framework Screwdriver to push against the lip.
결론
If you need help, contact Framework support.
작성자
2다른 기여자 명과 함께
Arthur Shi
회원 가입일: 01/03/18
309,598 평판
안내서 701개를 작성함
Guide Team Guide Team 회원
Staff
10 회원들
안내서 15,763개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 31
전체 시간: 316
