주요 콘텐츠로 건너뛰기
How to Install macOS Catalina on Unsupported Macs
필요한 것
  1. How to Install macOS Catalina on Unsupported Macs, Download the Patching Tool: 1 단계, 이미지 1개 중 1개
    • macOS Catalina Patcher can be downloaded from http://dosdude1.com/catalina/
    • Before beginning, ensure your model is compatible under the "System Compatibility" tab on the page. Most 2008 to 2011 Macs are compatible with the patching tool.
    • macOS Catalina Patcher is a third-party tool developed by dosdude1, who has developed trusted, similar tools since macOS Sierra.
    • Once the patching tool has downloaded, open the DMG file to mount it.
    • In the virtual drive, right click the "macOS Catalina Patcher", and click "Open".
    • If a warning appears saying that Apple cannot check the application for malicious software, click "Open" if it is an option, if "Close" is the only option, click it, then go into Security & Privacy in System Preferences, unlock the General tab and click "Open Anyway".
    • Continue through the prompts until you reach the "macOS Installer App" page.
    • Click "Download a Copy" to download an official macOS Catalina installer directly from Apple.
    • Click "Start Download".
    • If prompted, allow macOS Catalina Patcher access to your Downloads folder.
    • The download is an 8 GB file and may take some time to complete.
결론
That’s it! You should now have macOS Catalina installed on your machine.
다른 36명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Jonah Aragon
회원 가입일: 08/05/18
5,672 평판
안내서 5개를 작성함
Experimax Coon Rapids Experimax Coon Rapids 회원
Business
3 회원들
안내서 19개를 작성함
22가이드 댓글
Hi, the Catalina install doesn’t work for me on a MBP early 2011. Have tried all of the three install alternatives.
Klas
Klas Kallin - 답글
a mi tampoco me ha funcionado y tengo un MBP late 2011. mi correo es luisguillermopalomino@gmail.com si quieres ponerte en contacto por si descubres la solucion
Luis Guillermo Palomino Arias -
Hi there, I’m successfully running Catalina on an 8,1 iMac from 2008, so sweet! Only problem is that I can’t install some apps, like iWork/Pages or GarageBand. Is there any workaround for me to install Pages, especially? I hadn’t owned it before, so that option wouldn’t work for me.
Thanks in advance! :)
Felipe Leal - 답글
Install newer macOS maybe?
[deleted] -
The dosdude website is no longer responding. Any other recommendations?
Frank - 답글
댓글 쓰기
조회 통계:
지난 24시간: 45
지난 7일: 216
지난 30일: 1,040
전체 시간: 116,707
