이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Unzip your clean jacket and slide one half over your ironing board.
Flatten your jacket with your hands.
Set your iron to its lowest setting.
Ensure that the steam function of your iron is off.
Lay a towel over the area of your jacket that you'll be ironing.
Smooth the towel out with your hands.
Starting near the center, iron the jacket in one smooth stroke running parallel to the zipper.
Remove the towel from your jacket.
Inspect your work.
If it looks as though the iron did nothing, you can increase the heat of your iron by one setting and try ironing again.
If your work looks good, position another section of the jacket flat on the ironing board, re-cover it with the towel and repeat the process until your whole jacket is wrinkle-free.
다른 19명이 해당 안내서를 완성하였습니다.
댓글 14개
Thank you, good advice for younger generation who have clue.
Thank you - good reminder for the older generation who have lost their marbles
Thank you- good reminder for the baby boomer middle aged who voted for Brexit and haven't got a clue.
fixxysugar - 답글
