소개
A jump start is necessary when your battery has stopped working, causing your car not to start. Using another car and booster (jumper) cables, the battery can recharge and your car should start again. This guide will direct you on how to properly jump start your Jeep Wrangler.
도구
No tools specified.
부품
  1. Locate the two grey latches on each side of the hood near the headlights. Pull the latches away from the hood to release the latches.
    • Locate the two grey latches on each side of the hood near the headlights.
    • Pull the latches away from the hood to release the latches.
  2. Reach underneath the hood and push up on the lever located in the front center of the hood.  You can now open the hood. Prop the hood open by inserting the hood support rod into the designated hole on the underside of the hood.
    • Reach underneath the hood and push up on the lever located in the front center of the hood. You can now open the hood.
    • Prop the hood open by inserting the hood support rod into the designated hole on the underside of the hood.
  3. 아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
    아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
  4. Park a second vehicle front-to-front within 10 feet of the Jeep. Open the hood.
    • Park a second vehicle front-to-front within 10 feet of the Jeep. Open the hood.
    • Your car must be turned OFF to avoid getting electrocuted.
    • Be sure to have everything in the Jeep switched to the OFF position, including AC, headlights, radio, etc. to avoid getting electrocuted.
    • Leave the other vehicle's engine running.
  5. Be careful with the booster cable clamp in order to avoid damaging your vehicle and getting electrocuted and NEVER allow the red and black cable clamps to touch each other. Bring out the booster cables. You must attach the cables in THIS order to the batteries of both vehicles: 1) Connect one red clamp to the positive battery terminal on the Jeep (it will be the red spot on the battery) (Picture 1)
    • Be careful with the booster cable clamp in order to avoid damaging your vehicle and getting electrocuted and NEVER allow the red and black cable clamps to touch each other.
    • Bring out the booster cables. You must attach the cables in THIS order to the batteries of both vehicles:
    • 1) Connect one red clamp to the positive battery terminal on the Jeep (it will be the red spot on the battery) (Picture 1)
    • 2) Connect the other red clamp to the positive battery terminal on the other working vehicle (Picture 2).
    • 3) Connect one black clamp to the negative battery terminal on the other working vehicle (the negative terminal will be black and next to the red, positive terminal) (Picture 2).
    • 4) Clip the other black clamp to an unpainted metal nut on a brace next to the Jeep's battery (Picture 3).
  6. Leave the booster cables attached to both vehicles for approximately 10 minutes before attempting to start the Jeep.  If it does not start right away, wait 30 seconds and try again. Continue to try until it starts, taking short breaks in between attempts.
    • Leave the booster cables attached to both vehicles for approximately 10 minutes before attempting to start the Jeep. If it does not start right away, wait 30 seconds and try again. Continue to try until it starts, taking short breaks in between attempts.
    • Once the engine starts, let the Jeep run for about 5 minutes to recharge the battery.
    • In reverse order, remove the booster cables now that the Jeep is running and the battery has recharged.
결승점
다른 3명이 해당 안내서를 완성하였습니다.
Adam Donald
회원 가입일: 2012년 09월 26일
242 평판
안내서 4개 작성하였습니다
Cal Poly, Team 7-51, Forte Fall 2012 Cal Poly, Team 7-51, Forte Fall 2012 회원
CPSU-FORTE-F12S7G51
5 회원들
안내서 9개 작성하였습니다
Nice and easy. I wold prefer 2 gauge booster cables.
Arif javed - 답글
I would highly recommend that every one in this whole world to buy portable battery jumper after going through review.
Marwat Qureshi - 답글
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 39
지난 30일: 203
전체 시간: 15,876
