주요 콘텐츠로 건너뛰기
How to Keurig K75 Platinum Brewing System
필요한 것
  1. How to Keurig K75 Platinum Brewing System, How to Keurig K75 Platinum Brewing System: 1 단계, 이미지 1/2 How to Keurig K75 Platinum Brewing System, How to Keurig K75 Platinum Brewing System: 1 단계, 이미지 2/2
    • Before beginning the repair, turn off and unplug the brewer from any power source.
    • Move the brewer so that the bottom is easily accessible.
    • Unscrew the five 4mm silver diagrammed screws using a #2 Philips Head screwdriver.
  2. How to Keurig K75 Platinum Brewing System: 2 단계, 이미지 1/2 How to Keurig K75 Platinum Brewing System: 2 단계, 이미지 2/2
    • Using a spudger, gently pry open the base metal plate from the brewer.
    • Gently place the base of the brewer down.
  3. How to Keurig K75 Platinum Brewing System: 3 단계, 이미지 1/1
    • Locate the vacuum apparatus within the Keurig B70 Platinum.
    • Using a #00 Phillips screwdriver, unscrew the three 15 mm black screws diagrammed.
  4. How to Keurig K75 Platinum Brewing System: 4 단계, 이미지 1/1
    • Using a spudger, lift the white piece of the vacuum away from the black membrane.
    • Realign the circular pieces of the membrane so that the circles lie flush inside the black membrane apparatus.
결론
다른 14명이 해당 안내서를 완성하였습니다.
Kristen Temnyk
회원 가입일: 01/24/13
515 평판
안내서 3개 작성하였습니다
Cal Poly, Team 20-2, Maness Winter 2013 Cal Poly, Team 20-2, Maness Winter 2013 회원
CPSU-MANESS-W13S20G2
4 회원들
안내서 6개 작성하였습니다
댓글 22개
Thank you for this, it saved me from having to purchase a new Keurig. My Keurig was not pushing water out for a cup of coffee. I tried the paperclip in the needle, which didn't work. Thanks again!!!!!
gleasonme - 답글
I cant get the little screws off of the vacuum. I broke 3 screwdrivers. Could they be glued?
Christina Garrity - 답글
After you take the white piece of the vaccuum pump off, you will see the black rubber diaphragm just below. DO NOT REMOVE the black rubber diaphragm. It is not necessary to remove this piece, and it will NOT BE POSSIBLE to re-assemble the pump after you remove it. Just clear any obstructions and put the white piece with the tube back on.
I removed the black diaphragm before I realized what it was, and now my Keurig K75 Platinum ($) is heading to the landfill. Hopefully this will prevent somebody else from making that same mistake.
John - 답글
Dang... didn't expect it to work... but it did!!
kimmpowers2004 - 답글
This worked for me. When i took off the white piece 2 of the 3 little rubbery, indented pieces were recessed and one was popped out a bit. I pushed them all in and it seemingly fixed the problem. I ran it about three times so far and it is working properly so hopefully it stays working for a while.
rsivisoulivi - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 11
30일 전: 37
전체 시간: 34,601
