주요 콘텐츠로 건너뛰기
How to Koss Porta Pro
필요한 것
  1. How to Koss Porta Pro, How to Koss Porta Pro: 1 단계, 이미지 1/3 How to Koss Porta Pro, How to Koss Porta Pro: 1 단계, 이미지 2/3 How to Koss Porta Pro, How to Koss Porta Pro: 1 단계, 이미지 3/3
    • You will need:
    • A cable with a 3.5mm stereo plug at one end
    • Side cutting nippers
    • (precision)solder with soldering tin
  2. How to Koss Porta Pro: 2 단계, 이미지 1/3 How to Koss Porta Pro: 2 단계, 이미지 2/3 How to Koss Porta Pro: 2 단계, 이미지 3/3
    • The first step is to remove the earphones from the rack. It's very easy because they are only clipped in. Put one finger between the rack and the phone and slowly pull to remove it.
    • You should also remove the protection pads for further steps
    • With the help of a flathead screwdriver remove the blue case that sits upon the connectors. Be careful with that step and lift it from both sides bit by bit
    • Notice some sort of glue patch between the connectors. DO NOT TRY TO REMOVE THIS GLUE as it protects two very small wires that take the signal from the connectors to the earphones on the other side.
  3. How to Koss Porta Pro: 3 단계, 이미지 1/3 How to Koss Porta Pro: 3 단계, 이미지 2/3 How to Koss Porta Pro: 3 단계, 이미지 3/3
    • Cut the with the side cutting nippers behind the (cinch)plugs
    • remove about 1,5cm of insulation
    • part each 2 wires of each cable
    • As in the picture one cable is not extra insulated this is in my case the ground. The other one carries the signal.
    • Edit: The replacement cable in the pictures had problems... sadly. I think it was because of the long jack-plug. But I found some old apple In-Ear phones with a microphone and used that cable. Now I've got even a microphone on my koss Porta pro!
  4. How to Koss Porta Pro: 4 단계, 이미지 1/3 How to Koss Porta Pro: 4 단계, 이미지 2/3 How to Koss Porta Pro: 4 단계, 이미지 3/3
    • Put some soldering tin on the endings of the deinsulated cables
    • unsold the original cable from the earphones
    • As you can see the right connection has a red dot. This is where you have to sold the cable that carries the signal(In the first picture the insulated one)
    • Arrange the cables before soldering like in the second picture. This formation seems like the best to fix the cable best
    • Sold them and put everything together again. Try this http://www.youtube.com/watch?v=e8ODm-F9-... to find out where to clip them into the rack again :)
결론
다른 29명이 해당 안내서를 완성하였습니다.
Johannes Vix
회원 가입일: 04/02/12
823 평판
안내서 1개 작성함
댓글 6개
Thanks for the tutorial. With the detailed description and the pictures it was very easy to fix the porta pro. Greatings from Leipzig. =)
Hans - 답글
Hey,
nice to see this guide here.
I actually used a cable from a headset with a microphone and a button) and now I love my Porta Pros more than ever! It's so comfortable to skip through the music without having to take out the phone.
I first used an Apple-Headset and then learned that their buttons aren't really compatible to Android so I switched the cable another time and used the one from the headset that came along with my phone. They look like this:
http://ecx.images-amazon.com/images/I/41...
Cheers from Oldenburg!
Halle Luja - 답글
Thank you a lot, also EU so it has to be done ;)
Hrvoje Marin - 답글
Thanks for the tutorial! I fixed mine early this morning, 2 more to go … Greetings from the Blackforest …
Ruben Jenster - 답글
I live in the EU as well, but I got replacements from Koss for free and within a few days by contacting their local affiliate branch in my country.
I would expect that you could do that as well in a lot of countries outside the US.
Check here for your country:
https://www.koss.com/support/distributor...
Core - 답글
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 90
30일 전: 358
전체 시간: 73,525
