주요 콘텐츠로 건너뛰기
How to Lengthen a Necklace Chain
필요한 것
  1. How to Lengthen a Necklace Chain, How to Lengthen a Necklace Chain: 1 단계, 이미지 1/1
    • Measure and determine the desired length of jewelry chain that you want to add.
    • Place a piece of tape to mark where you want to cut.
  2. How to Lengthen a Necklace Chain: 2 단계, 이미지 1/1
    • Cut the extender chain with wire cutters/scissors at the tape marker.
  3. How to Lengthen a Necklace Chain: 3 단계, 이미지 1/1
    • Look at your jump ring. If there is no opening in the jump ring, carefully cut the ring yourself with scissors.
  4. How to Lengthen a Necklace Chain: 4 단계, 이미지 1/1
    • Use jewelry pliers to open the jump ring at one end of the extender chain and one end of the jewelry chain.
  5. How to Lengthen a Necklace Chain: 5 단계, 이미지 1/1
    • Connect one end of the extender chain to the jump rings.
    • Repeat the process by attaching one end of the jewelry chain to the same jump ring the extender chain is on.
  6. How to Lengthen a Necklace Chain: 6 단계, 이미지 1/1
    • With the jewelry pliers, carefully squeeze the jump ring shut, ensuring both the extender chain and jewelry chain remain securely attached to it.
  7. How to Lengthen a Necklace Chain: 7 단계, 이미지 1/1
    • Make sure that the extender chain's closure is secure and won’t open or come loose during wear. If everything seems correct, you are ready to wear it!
결승점
Faith Low
회원 가입일: 04/26/24
145 평판
안내서 1개 작성함
UC Davis, Team 2-3, Whithaus Spring 2024 UC Davis, Team 2-3, Whithaus Spring 2024 회원
UCD-WHITHAUS-S24S2G3
4 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 24
전체 시간: 54
