주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
My previous repair guide has explained how to turn an iPhone 11 Pro into an iPhone 11 Pro Max by removing an extra board ID resistor on iPhone 11 Pro. Well, you might wonder how to Locate the Board ID resistor on iPhone motherboards? We will take iPhone 6s plus as an example and show you the tricks.
도구
부품
지정된 부품이 없습니다.
  1. Let's take iPhone 6s Plus as an example. Open Refox and search Board_ID of of iPhone 6s Plus
    • Let's take iPhone 6s Plus as an example.
    • Open Refox and search Board_ID of of iPhone 6s Plus
    • We can see 5 Board ID resistors on the schematic. R0404, R0405, R0406, R0407 and R0408.
  2. The board ID of iPhone 6s Plus is N66 MLB. Board ID resistors of iPhone 6s Plus are arranged in an array of 00110. Which means resistors on BOARD_ID1 and BOARD_ID2 should be kept. The board ID of iPhone 6s is N71 MLB. Board ID resistors of iPhone 6s are arranged in an array of 00100. Which means the resistor on BOARD_ID2 should be kept.
    • The board ID of iPhone 6s Plus is N66 MLB. Board ID resistors of iPhone 6s Plus are arranged in an array of 00110. Which means resistors on BOARD_ID1 and BOARD_ID2 should be kept.
    • The board ID of iPhone 6s is N71 MLB. Board ID resistors of iPhone 6s are arranged in an array of 00100. Which means the resistor on BOARD_ID2 should be kept.
  3. LCD iPhone 스크린 수리 키트
    평생 품질 보증이 적용되는 저렴한 옵션.
    키트 쇼핑하기
    수리의 질 말고 비용을 절감하세요.
    키트 쇼핑하기
  4. To turn iPhone 6s Plus into iPhone 6s, all we need to do is to remove R0407 on BOARD_ID1.
    • To turn iPhone 6s Plus into iPhone 6s, all we need to do is to remove R0407 on BOARD_ID1.
    • Compare the logic board of iPhone 6s and that of iPhone 6s Plus. There is one more board ID resistor on iPhone 6s Plus. This one is R0407 as mentioned above.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
Phryne
회원 가입일: 2019년 11월 17일
5,704 평판
안내서 43개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 14
30일 전: 53
전체 시간: 320
