주요 콘텐츠로 건너뛰기
How to Lubricate a Zipper
필요한 것
  1. How to Lubricate a Zipper, How to Lubricate a Zipper: 1 단계, 이미지 3개 중 1개 How to Lubricate a Zipper, How to Lubricate a Zipper: 1 단계, 이미지 3개 중 2개 How to Lubricate a Zipper, How to Lubricate a Zipper: 1 단계, 이미지 3개 중 3개
    • Lay your garment on a table.
    • If you can, unzip the zipper.
    • If you can't move the slider, just work around it.
    • Using the brush located on top of the Zip Care bottle, or simply using a nylon brush, work the dirt and debris off of the zipper coil or the teeth of the zipper.
  2. How to Lubricate a Zipper: 2 단계, 이미지 2개 중 1개 How to Lubricate a Zipper: 2 단계, 이미지 2개 중 2개
    • Pinch the slider in your fingers, so that you can see into the area where the coil rests.
    • Use the brush to free any dirt or debris caught inside the slider.
  3. How to Lubricate a Zipper: 3 단계, 이미지 3개 중 1개 How to Lubricate a Zipper: 3 단계, 이미지 3개 중 2개 How to Lubricate a Zipper: 3 단계, 이미지 3개 중 3개
    • Place a paper towel behind the zipper.
    • To prevent messes, make sure that the paper towel is touching the underside of the teeth or coil.
  4. How to Lubricate a Zipper: 4 단계, 이미지 3개 중 1개 How to Lubricate a Zipper: 4 단계, 이미지 3개 중 2개 How to Lubricate a Zipper: 4 단계, 이미지 3개 중 3개
    • Twist open the Zip Care.
    • Gently squeeze the bottle as you slide the brush along the teeth or coil of the zipper to apply the lubricant.
    • Repeat this on both sides of the zipper teeth or coil.
  5. How to Lubricate a Zipper: 5 단계, 이미지 2개 중 1개 How to Lubricate a Zipper: 5 단계, 이미지 2개 중 2개
    • Fold the paper towel over and dab any excess lubricant off the zipper.
  6. How to Lubricate a Zipper: 6 단계, 이미지 2개 중 1개 How to Lubricate a Zipper: 6 단계, 이미지 2개 중 2개
    • Zip and unzip the zipper a few times to work the lubricant in between the teeth or coil.
결승점
다른 6명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Brittany McCrigler
회원 가입일: 03/05/12
90,451 평판
안내서 142개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,639개를 작성함
1가이드 댓글
Hi Brittany, I’m hoping you have an answer for my favourite purse. The zipper is frozen due to the remnant of a plastic bag I put in my purse. Please advise!
Clair - 답글
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 69
지난 30일: 354
전체 시간: 119,967
