주요 콘텐츠로 건너뛰기
How to Lubricate the Belt on a Horizon Fitness TempoT611T Treadmill
필요한 것
  1. How to Lubricate the Belt on a Horizon Fitness TempoT611T Treadmill, How to Lubricate the Belt on a Horizon Fitness TempoT611T Treadmill: 1 단계, 이미지 1개 중 1개
    • Unplug the treadmill from the wall outlet before you begin.
    • Loosen the screws in the deck of the treadmill at the edge of the machine using a screwdriver.
  2. How to Lubricate the Belt on a Horizon Fitness TempoT611T Treadmill: 2 단계, 이미지 1개 중 1개
    • Gently lift the belt.
  3. How to Lubricate the Belt on a Horizon Fitness TempoT611T Treadmill: 3 단계, 이미지 1개 중 1개
    • Take a clean cloth to wipe out any dust or debris.
  4. How to Lubricate the Belt on a Horizon Fitness TempoT611T Treadmill: 4 단계, 이미지 1개 중 1개
    • Apply lubricant under the belt, starting from the center and working your way to the edge.
    • Wear gloves as the lubricant is filled with chemicals.
  5. How to Lubricate the Belt on a Horizon Fitness TempoT611T Treadmill: 5 단계, 이미지 1개 중 1개
    • Tighten the screws in the treadmill deck using a screwdriver.
  6. How to Lubricate the Belt on a Horizon Fitness TempoT611T Treadmill: 6 단계, 이미지 1개 중 1개
    • Start the treadmill again and ensure it works without creaking noises.
결론
You did it! Oiling your treadmill is an essential maintenance task that ensures the longevity and optimal performance of your equipment. Regularly oiling the machine helps to reduce friction, noise, and wear and tear on the moving parts, making your workouts safer and more comfortable. Neglecting this task can lead to serious damage to your treadmill, which can be expensive to repair or replace. Therefore, it is recommended that you oil your treadmill every three to six months, depending on how frequently you use it. By taking good care of your equipment, you can enjoy a smooth and hassle-free treadmill workout for years to come.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Batul Ismail
회원 가입일: 05/25/23
133 평판
안내서 1개를 작성함
York University, Team A-4, Allen Summer 2023 York University, Team A-4, Allen Summer 2023 회원
YORK-ALLEN-SU23SAG4
2 회원들
안내서 1개 작성
1가이드 댓글
Thank you for your service. Please post the repair of the Xiaomi X21 treadmill electronic panel on the website.
saeid meshkinfar - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 14
전체 시간: 370
