주요 콘텐츠로 건너뛰기
How to Make a Hockey Stick Longer
필요한 것
  1. How to Make a Hockey Stick Longer, How to Make a Hockey Stick Longer: 1 단계, 이미지 2개 중 1개 How to Make a Hockey Stick Longer, How to Make a Hockey Stick Longer: 1 단계, 이미지 2개 중 2개
    • Procure an extender that will fit your stick.
    • Your stick should say if it is a junior or senior stick; get the corresponding extender.
  2. How to Make a Hockey Stick Longer: 2 단계, 이미지 1개 중 1개
    • Remove the tape on the end of the stick.
  3. How to Make a Hockey Stick Longer: 3 단계, 이미지 1개 중 1개
    • Remove the plug/stopper from the end of the stick using a spudger.
  4. How to Make a Hockey Stick Longer: 4 단계, 이미지 2개 중 1개 How to Make a Hockey Stick Longer: 4 단계, 이미지 2개 중 2개
    • Heat the glue on the extender with a hair dryer for approximately four minutes.
    • The glue should look wet and sticky.
  5. How to Make a Hockey Stick Longer: 5 단계, 이미지 1개 중 1개
    • Heat the end of the stick up where you will insert the extender for about five minutes.
  6. How to Make a Hockey Stick Longer: 6 단계, 이미지 3개 중 1개 How to Make a Hockey Stick Longer: 6 단계, 이미지 3개 중 2개 How to Make a Hockey Stick Longer: 6 단계, 이미지 3개 중 3개
    • Insert the extender into the butt of the stick.
    • You can flip the stick and use the ground to help get the extender in all the way since it is a snug fit.
    • You can use the hair dryer as needed to heat the glue and the stick up more if you are having a hard time getting the extender in.
  7. How to Make a Hockey Stick Longer: 7 단계, 이미지 1개 중 1개
    • Wipe the excess glue where the stick and extender join with a rag or napkin.
    • Allow the glue to dry for about 10 minutes.
    • You can also go onto the next step if the stick is cooled down to normal temperature.
  8. How to Make a Hockey Stick Longer: 8 단계, 이미지 2개 중 1개 How to Make a Hockey Stick Longer: 8 단계, 이미지 2개 중 2개
    • Tape the top of the stick or install grip tape (optional).
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Izzy
회원 가입일: 10/01/24
181 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 14
전체 시간: 195
