주요 콘텐츠로 건너뛰기
How to Make a Jeans Patch Less Noticeable
필요한 것
  1. How to Make a Jeans Patch Less Noticeable, How to Make a Jeans Patch Less Noticeable: 1 단계, 이미지 2개 중 1개 How to Make a Jeans Patch Less Noticeable, How to Make a Jeans Patch Less Noticeable: 1 단계, 이미지 2개 중 2개
    • Place the jeans on an even surface.
    • Flip your jeans inside out.
  2. How to Make a Jeans Patch Less Noticeable: 2 단계, 이미지 3개 중 1개 How to Make a Jeans Patch Less Noticeable: 2 단계, 이미지 3개 중 2개 How to Make a Jeans Patch Less Noticeable: 2 단계, 이미지 3개 중 3개
    • Trim any loose thread around the hole.
    • After cleaning the area, use the iron to warm the area before placing the patch.
  3. How to Make a Jeans Patch Less Noticeable: 3 단계, 이미지 2개 중 1개 How to Make a Jeans Patch Less Noticeable: 3 단계, 이미지 2개 중 2개
    • Grab the patch and iron it on until it is secured to the jeans.
  4. How to Make a Jeans Patch Less Noticeable: 4 단계, 이미지 3개 중 1개 How to Make a Jeans Patch Less Noticeable: 4 단계, 이미지 3개 중 2개 How to Make a Jeans Patch Less Noticeable: 4 단계, 이미지 3개 중 3개
    • Start preparing your thread and needle and knot the end of the thread.
    • Push the needle from the back to the front.
    • Create an outline of the part where the patch is visible, until a circle is formed.
  5. How to Make a Jeans Patch Less Noticeable: 5 단계, 이미지 3개 중 1개 How to Make a Jeans Patch Less Noticeable: 5 단계, 이미지 3개 중 2개 How to Make a Jeans Patch Less Noticeable: 5 단계, 이미지 3개 중 3개
    • Push the needle from the back to the front, filling in the hole.
    • Repeat this process until the hole is covered and the patch is not showing.
    • Tie off the thread in a knot on the inside of the jeans.
  6. How to Make a Jeans Patch Less Noticeable: 6 단계, 이미지 2개 중 1개 How to Make a Jeans Patch Less Noticeable: 6 단계, 이미지 2개 중 2개
    • Grabbing a new color thread, tie off a knot like mentioned in step 4.
    • Starting inside, create your desired design (we decided a moon and stars).
    • Push the needle back to front creating little clumps within the hole.
    • When you have finished the design tie it off on the inside of the jeans.
  7. How to Make a Jeans Patch Less Noticeable: 7 단계, 이미지 1개 중 1개
    • Cut a new piece of thread and place it on the inside.
    • Push the needle back to front of the jeans and push it back inside a few centimeters down.
    • Repeat this threading technique a few times, creating a star.
    • Tie off the thread on the inside of the jean.
    • Cut any excess thread from the inside of the jean.
    • Jeans are now ready to be worn.
결승점
작성자
3다른 기여자 명과 함께
Alejandra Gonzalez Manzo
회원 가입일: 04/22/24
145 평판
안내서 1개를 작성함
UC Davis, Team 2-5, Whithaus Spring 2024 UC Davis, Team 2-5, Whithaus Spring 2024 회원
UCD-WHITHAUS-S24S2G5
3 회원들
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 22
지난 30일: 53
전체 시간: 529
