주요 콘텐츠로 건너뛰기
How to Make an Affordable Soldering Fume Extractor
필요한 것
  1. How to Make an Affordable Soldering Fume Extractor, Overview: 1 단계, 이미지 2개 중 1개 How to Make an Affordable Soldering Fume Extractor, Overview: 1 단계, 이미지 2개 중 2개
    • This fume extractor is composed of three main parts: a 12V computer fan, cardboard box enclosure, and activated carbon filter.
    • Solder often contains rosin flux. When vaporized during soldering, it's a respiratory and eye irritant and can cause health issues when inhaled long term.
    • This extractor pulls the harmful fumes into the charcoal filter trapping volatile compounds, removing them from the air.
  2. How to Make an Affordable Soldering Fume Extractor, Position the fan on the box: 2 단계, 이미지 1개 중 1개
    • Position the fan over the box so that an exhaust cutout can be made.
  3. How to Make an Affordable Soldering Fume Extractor, Poke fan mounting holes: 3 단계, 이미지 3개 중 1개 How to Make an Affordable Soldering Fume Extractor, Poke fan mounting holes: 3 단계, 이미지 3개 중 2개 How to Make an Affordable Soldering Fume Extractor, Poke fan mounting holes: 3 단계, 이미지 3개 중 3개
    • Use a pointy object like a screwdriver to poke four fan mounting holes into the box.
  4. How to Make an Affordable Soldering Fume Extractor, Trace the inside diameter of the fan onto the box: 4 단계, 이미지 3개 중 1개 How to Make an Affordable Soldering Fume Extractor, Trace the inside diameter of the fan onto the box: 4 단계, 이미지 3개 중 2개 How to Make an Affordable Soldering Fume Extractor, Trace the inside diameter of the fan onto the box: 4 단계, 이미지 3개 중 3개
    • Use a pen or pencil to mark the inside diameter of the fan onto the box.
  5. How to Make an Affordable Soldering Fume Extractor, Cut out the exhaust port: 5 단계, 이미지 3개 중 1개 How to Make an Affordable Soldering Fume Extractor, Cut out the exhaust port: 5 단계, 이미지 3개 중 2개 How to Make an Affordable Soldering Fume Extractor, Cut out the exhaust port: 5 단계, 이미지 3개 중 3개
    • Use a razor blade to cut out the fan exhaust port.
  6. How to Make an Affordable Soldering Fume Extractor, Poke four more fan mounting holes: 6 단계, 이미지 3개 중 1개 How to Make an Affordable Soldering Fume Extractor, Poke four more fan mounting holes: 6 단계, 이미지 3개 중 2개 How to Make an Affordable Soldering Fume Extractor, Poke four more fan mounting holes: 6 단계, 이미지 3개 중 3개
    • Poke four more holes about 1 cm out from the ones you made earlier.
  7. How to Make an Affordable Soldering Fume Extractor, Mark the intake port: 7 단계, 이미지 2개 중 1개 How to Make an Affordable Soldering Fume Extractor, Mark the intake port: 7 단계, 이미지 2개 중 2개
    • Flip the box over.
    • Use a pen or a pencil and a straight edge to mark out the intake port.
    • Leave a lip so the filter material won't fall out when placed inside the box.
  8. How to Make an Affordable Soldering Fume Extractor, Cut out the intake port: 8 단계, 이미지 3개 중 1개 How to Make an Affordable Soldering Fume Extractor, Cut out the intake port: 8 단계, 이미지 3개 중 2개 How to Make an Affordable Soldering Fume Extractor, Cut out the intake port: 8 단계, 이미지 3개 중 3개
    • Use a razor blade to cut out the intake port in the box.
  9. How to Make an Affordable Soldering Fume Extractor, Thread zip ties through the fan mount holes: 9 단계, 이미지 1개 중 1개
    • Thread four zip ties through the fan mounting holes.
  10. How to Make an Affordable Soldering Fume Extractor, Cut the filter to size: 10 단계, 이미지 3개 중 1개 How to Make an Affordable Soldering Fume Extractor, Cut the filter to size: 10 단계, 이미지 3개 중 2개 How to Make an Affordable Soldering Fume Extractor, Cut the filter to size: 10 단계, 이미지 3개 중 3개
    • Activated carbon filters come in all shapes and sizes. You may need to cut and modify the filter to fit your enclosure.
    • Cut the filter so it will fit snugly in the intake port.
  11. How to Make an Affordable Soldering Fume Extractor, Insert the filter into the intake port: 11 단계, 이미지 2개 중 1개 How to Make an Affordable Soldering Fume Extractor, Insert the filter into the intake port: 11 단계, 이미지 2개 중 2개
    • Insert the filter into the intake port.
    • If your filter doesn't span the intake port, you can use glue or tape to connect multiple filter sections together.
  12. How to Make an Affordable Soldering Fume Extractor, Secure the fan to the exhaust port: 12 단계, 이미지 3개 중 1개 How to Make an Affordable Soldering Fume Extractor, Secure the fan to the exhaust port: 12 단계, 이미지 3개 중 2개 How to Make an Affordable Soldering Fume Extractor, Secure the fan to the exhaust port: 12 단계, 이미지 3개 중 3개
    • Thread the zip ties through the fan's mounting holes.
    • Make sure the fan's intake side is placed against the box hole, or you'll end up with a soldering fume blower.
    • Secure the fan to the exhaust port by tightening the zip ties.
    • Clip the excess zip tie strap.
  13. How to Make an Affordable Soldering Fume Extractor, Cut off the fan connector: 13 단계, 이미지 2개 중 1개 How to Make an Affordable Soldering Fume Extractor, Cut off the fan connector: 13 단계, 이미지 2개 중 2개
  14. How to Make an Affordable Soldering Fume Extractor, Thread the fan cable into the box: 14 단계, 이미지 3개 중 1개 How to Make an Affordable Soldering Fume Extractor, Thread the fan cable into the box: 14 단계, 이미지 3개 중 2개 How to Make an Affordable Soldering Fume Extractor, Thread the fan cable into the box: 14 단계, 이미지 3개 중 3개
    • Use a pointy object like a screwdriver to poke a hole in the box for the fan cable.
    • Thread the fan cable into the box.
  15. How to Make an Affordable Soldering Fume Extractor, Cut out a hole for the switch: 15 단계, 이미지 3개 중 1개 How to Make an Affordable Soldering Fume Extractor, Cut out a hole for the switch: 15 단계, 이미지 3개 중 2개 How to Make an Affordable Soldering Fume Extractor, Cut out a hole for the switch: 15 단계, 이미지 3개 중 3개
    • Use a pen or pencil to mark the outline of the switch.
    • Choose a convenient and easily accessible location.
    • Cut out a hole for the switch.
    • Pull the fan cable through the switch hole.
  16. How to Make an Affordable Soldering Fume Extractor, Wire up the fan, switch, and battery: 16 단계, 이미지 3개 중 1개 How to Make an Affordable Soldering Fume Extractor, Wire up the fan, switch, and battery: 16 단계, 이미지 3개 중 2개 How to Make an Affordable Soldering Fume Extractor, Wire up the fan, switch, and battery: 16 단계, 이미지 3개 중 3개
    • Before soldering, make sure the fan is wired up correctly. If the positive and negative wires are switched, the fan might burn out.
    • Solder the switch between the fan's positive wire and the battery's positive wire.
    • Solder the negative fan wire to the negative battery wire.
    • Pull the excess cable back through and mount the switch to the box.
  17. How to Make an Affordable Soldering Fume Extractor, Place the electronics in the box: 17 단계, 이미지 1개 중 1개
    • Place the loose wires in the box.
    • Secure the 9V battery to the interior of the box using double sided tape.
  18. How to Make an Affordable Soldering Fume Extractor, Admire your creation: 18 단계, 이미지 2개 중 1개 How to Make an Affordable Soldering Fume Extractor, Admire your creation: 18 단계, 이미지 2개 중 2개
    • Rejoice! The days of holding your breath or inhaling solder fumes are over.
    • If your solder fumes are especially potent and are visible in the exhaust, you can stack additional filter material to trap them.
결론
Now that you've created a fume extractor, check out some of our soldering guides or stop by our store for supplies you might need on your soldering journey.
다른 36명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Chayton Ritter
회원 가입일: 08/21/20
24,832 평판
안내서 105개를 작성함
Guide Team Guide Team 회원
Staff
10 회원들
안내서 15,766개를 작성함
14가이드 댓글
Nice job. As for those 9 volt batteries, you will find that when your smoke alarm starts beeping, the batteries still have plenty of life left for running the fan. No need to buy a new battery.
Phil - 답글
how long will the battery last? why not use a battery connector? so changing out the battery would be a lot easier.
Russell G Stewart - 답글
they do, it's easiest to see in the step 1 photo, but it's also there in step 17
X2Brute -
Why not put the fan in the box?
Why not reduce the inlet opening to the size of a smoke filter and thus save a filter?
Simon Martel - 답글
Why not indeed! I hear a v2 in the making :)
Shahram Mokhtari -
댓글 쓰기
조회 통계:
지난 24시간: 53
지난 7일: 350
지난 30일: 1,537
전체 시간: 28,961
