주요 콘텐츠로 건너뛰기
How to Manually Eject a Stuck Disc in a PlayStation 5
필요한 것
  1. How to Manually Eject a Stuck Disc in a PlayStation 5, How to Manually Eject a Stuck Disc in a PlayStation 5: 1 단계, 이미지 3개 중 1개 How to Manually Eject a Stuck Disc in a PlayStation 5, How to Manually Eject a Stuck Disc in a PlayStation 5: 1 단계, 이미지 3개 중 2개 How to Manually Eject a Stuck Disc in a PlayStation 5, How to Manually Eject a Stuck Disc in a PlayStation 5: 1 단계, 이미지 3개 중 3개
    • Unplug all cables going into the console (power, ethernet, hdmi and etc).
    • This should be done for your safety and for the safety of the device.
  2. How to Manually Eject a Stuck Disc in a PlayStation 5: 2 단계, 이미지 3개 중 1개 How to Manually Eject a Stuck Disc in a PlayStation 5: 2 단계, 이미지 3개 중 2개 How to Manually Eject a Stuck Disc in a PlayStation 5: 2 단계, 이미지 3개 중 3개
    • If you are using a stand to hold your PlayStation, locate the screw at the bottom.
    • Using the flathead screwdriver, unscrew the 5mm Phillips screw from the base.
    • Remove the base, and place it off to the side.
  3. How to Manually Eject a Stuck Disc in a PlayStation 5: 3 단계, 이미지 3개 중 1개 How to Manually Eject a Stuck Disc in a PlayStation 5: 3 단계, 이미지 3개 중 2개 How to Manually Eject a Stuck Disc in a PlayStation 5: 3 단계, 이미지 3개 중 3개
    • Place the PlayStation on the side without the PlayStation logo.
    • Pull up on the top right corner of the PlayStation . This corner can be found diagonally across from the disc tray. Pull the cover toward the disc tray, in a diagonal direction.
    • To remove the white cover, it may take some force.
  4. How to Manually Eject a Stuck Disc in a PlayStation 5: 4 단계, 이미지 2개 중 1개 How to Manually Eject a Stuck Disc in a PlayStation 5: 4 단계, 이미지 2개 중 2개
    • Poke a hole through the black sticker with the Philip's head screwdriver or spudger.
    • Use the screwdriver as a key to turn the screw inside the black sticker clockwise.
    • The disc should come out after several turns.
결론
다른 11명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Jason Pinto
회원 가입일: 01/10/21
400 평판
안내서 1개를 작성함
1가이드 댓글
My Play station is different and it's a 5.
Cristine Kulkowsky - 답글
댓글 쓰기
조회 통계:
지난 24시간: 12
지난 7일: 95
지난 30일: 368
전체 시간: 13,996
