주요 콘텐츠로 건너뛰기
How to Manually Eject a Stuck Disc in a PlayStation 5
필요한 것
  1. How to Manually Eject a Stuck Disc in a PlayStation 5, How to Manually Eject a Stuck Disc in a PlayStation 5: 1 단계, 이미지 1/3 How to Manually Eject a Stuck Disc in a PlayStation 5, How to Manually Eject a Stuck Disc in a PlayStation 5: 1 단계, 이미지 2/3 How to Manually Eject a Stuck Disc in a PlayStation 5, How to Manually Eject a Stuck Disc in a PlayStation 5: 1 단계, 이미지 3/3
    • Unplug all cables going into the console (power, ethernet, hdmi and etc).
    • This should be done for your safety and for the safety of the device.
  2. How to Manually Eject a Stuck Disc in a PlayStation 5: 2 단계, 이미지 1/3 How to Manually Eject a Stuck Disc in a PlayStation 5: 2 단계, 이미지 2/3 How to Manually Eject a Stuck Disc in a PlayStation 5: 2 단계, 이미지 3/3
    • If you are using a stand to hold your PlayStation, locate the screw at the bottom.
    • Using the flathead screwdriver, unscrew the 5mm Phillips screw from the base.
    • Remove the base, and place it off to the side.
  3. How to Manually Eject a Stuck Disc in a PlayStation 5: 3 단계, 이미지 1/3 How to Manually Eject a Stuck Disc in a PlayStation 5: 3 단계, 이미지 2/3 How to Manually Eject a Stuck Disc in a PlayStation 5: 3 단계, 이미지 3/3
    • Place the PlayStation on the side without the PlayStation logo.
    • Pull up on the top right corner of the PlayStation . This corner can be found diagonally across from the disc tray. Pull the cover toward the disc tray, in a diagonal direction.
    • To remove the white cover, it may take some force.
  4. How to Manually Eject a Stuck Disc in a PlayStation 5: 4 단계, 이미지 1/2 How to Manually Eject a Stuck Disc in a PlayStation 5: 4 단계, 이미지 2/2
    • Poke a hole through the black sticker with the Philip's head screwdriver or spudger.
    • Use the screwdriver as a key to turn the screw inside the black sticker clockwise.
    • The disc should come out after several turns.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Jason Pinto
회원 가입일: 01/10/21
283 평판
안내서 1개 작성함
York University, Team S2-G18, O'Regan Winter 2021 York University, Team S2-G18, O'Regan Winter 2021 회원
YORK-O'REGAN-W21S2G18
1 회원
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 11
7일 전: 93
30일 전: 355
전체 시간: 6,322
