주요 콘텐츠로 건너뛰기
How to Mend Broken China
필요한 것
  1. How to Mend Broken China, How to Mend Broken China: 1 단계, 이미지 1개 중 1개
    • Wipe all broken edges with rubbing alcohol using a paper towel.
    • Do this to eliminate any grease and dirt.
    • Be aware that rubbing alcohol is highly flammable.
    • Be aware of sharp edges throughout this repair.
  2. How to Mend Broken China: 2 단계, 이미지 1개 중 1개
    • Pour epoxy into a smooth-surfaced container.
    • We used the plastic wrapping of the razor, but any container works.
    • Don't use epoxy in a small, confined space.
    • Do not get epoxy near eyes or on skin. Consider using polyethylene or polypropylene gloves.
  3. How to Mend Broken China: 3 단계, 이미지 1개 중 1개
    • Mix epoxy fluids with a toothpick.
    • The fluid sets in 5 minutes, so you must quickly apply it to the china. You can mix more if the first pour hardens.
  4. How to Mend Broken China: 4 단계, 이미지 2개 중 1개 How to Mend Broken China: 4 단계, 이미지 2개 중 2개
    • Apply the epoxy along the edges of the base piece of china and first chipped piece of china using the toothpick.
  5. How to Mend Broken China: 5 단계, 이미지 3개 중 1개 How to Mend Broken China: 5 단계, 이미지 3개 중 2개 How to Mend Broken China: 5 단계, 이미지 3개 중 3개
    • Attach the first detached piece to the base carefully by hand.
    • Adjust as needed.
    • Don't worry about excess epoxy at this point. It will be removed after setting.
  6. How to Mend Broken China: 6 단계, 이미지 2개 중 1개 How to Mend Broken China: 6 단계, 이미지 2개 중 2개
    • Apply epoxy on the next detached piece and the already mended piece
    • Use a tweezer to attach smaller fragments.
  7. How to Mend Broken China: 7 단계, 이미지 2개 중 1개 How to Mend Broken China: 7 단계, 이미지 2개 중 2개
    • Attach the piece to the china.
    • Adjust as needed
    • Repeat the process of applying epoxy and attaching the chips until all broken pieces are successfully in place.
  8. How to Mend Broken China: 8 단계, 이미지 1개 중 1개
    • Place mended china in a container of stabilizing sand or gravel.
    • This step is performed to put the right gravitational weight on the attachments so the pieces don't become unaligned during the setting of the epoxy.
    • Leave to set for at least 1 hour.
  9. How to Mend Broken China: 9 단계, 이미지 2개 중 1개 How to Mend Broken China: 9 단계, 이미지 2개 중 2개
    • Shave off as much excess epoxy as possible using the razor.
    • Exhibit caution when using the razors; they are very sharp!
  10. How to Mend Broken China: 10 단계, 이미지 2개 중 1개 How to Mend Broken China: 10 단계, 이미지 2개 중 2개
    • Use coarse sandpaper to further reduce the excess epoxy.
  11. How to Mend Broken China: 11 단계, 이미지 1개 중 1개
    • Use fine sandpaper to smooth out remaining inconsistencies.
  12. How to Mend Broken China: 12 단계, 이미지 2개 중 1개 How to Mend Broken China: 12 단계, 이미지 2개 중 2개
    • Darker cracks form where the clear epoxy functions as filler, but the cup will work perfectly fine! Add colored pigment to the epoxy for a more subtle repair.
결승점
다른 3명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Mikkeline Thomsen
회원 가입일: 04/28/17
141 평판
안내서 1개를 작성함
UC Davis, Team S1-G4, Coad Spring 2017 UC Davis, Team S1-G4, Coad Spring 2017 회원
UCD-COAD-S17S1G4
3 회원들
안내서 2개를 작성함
1가이드 댓글
Will this method work on ceramic?
Terry - 답글
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 36
지난 30일: 127
전체 시간: 23,212
