주요 콘텐츠로 건너뛰기
How to Mend a Hole in Mittens
필요한 것
  1. How to Mend a Hole in Mittens, How to Mend a Hole in Mittens: 1 단계, 이미지 2개 중 1개 How to Mend a Hole in Mittens, How to Mend a Hole in Mittens: 1 단계, 이미지 2개 중 2개
    • Examine the hole carefully to determine its size and shape. A small hole like the one displayed can be stitched over, while larger ones may require a patch.
  2. How to Mend a Hole in Mittens: 2 단계, 이미지 1개 중 1개
    • Turn the mitten inside out.
  3. How to Mend a Hole in Mittens: 3 단계, 이미지 2개 중 1개 How to Mend a Hole in Mittens: 3 단계, 이미지 2개 중 2개
    • Place the sewing pin along the hole to hold the fabric together until sewn.
  4. How to Mend a Hole in Mittens: 4 단계, 이미지 2개 중 1개 How to Mend a Hole in Mittens: 4 단계, 이미지 2개 중 2개
    • Set up the sewing machine.
    • Choose a stitch; to ensure a strong stitch, choose either a zigzag or straight stitch.
    • Thread the needle.
    • Choose a matching thread color for the least noticeable stitch.
  5. How to Mend a Hole in Mittens: 5 단계, 이미지 1개 중 1개
    • Begin sewing the hole.
  6. How to Mend a Hole in Mittens: 6 단계, 이미지 1개 중 1개
    • Stretch the mitten to test the repair.
결론
Fixing a mitten with a sewing machine is an easy way to make it last longer. Whether you’re stitching a small hole or adding a patch, a few simple steps can keep your mittens warm and useful. Instead of throwing them away, a quick repair can make them good as new!
작성자
2다른 기여자 명과 함께
Sonja
회원 가입일: 02/21/25
133 평판
안내서 1개를 작성함
UC Davis, Team 4-1, Andersen Winter 2025 UC Davis, Team 4-1, Andersen Winter 2025 회원
UCD-ANDERSEN-W25S4G1
2 회원들
안내서 1개 작성
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 14
전체 시간: 119
