주요 콘텐츠로 건너뛰기
How to Mend a Hole in a Cotton Blanket
필요한 것
  1. How to Mend a Hole in a Cotton Blanket, How to Mend a Hole in a Cotton Blanket: 1 단계, 이미지 1개 중 1개
    • Find the hole in the blanket
  2. How to Mend a Hole in a Cotton Blanket: 2 단계, 이미지 1개 중 1개
    • Put the needle through the blanket, right below the hole picking up just a little bit of the fabric and do not pull the thread all the way through.
  3. How to Mend a Hole in a Cotton Blanket: 3 단계, 이미지 2개 중 1개 How to Mend a Hole in a Cotton Blanket: 3 단계, 이미지 2개 중 2개
    • Repeat step 2 about 2 more times by inserting the needle through the same hole
  4. How to Mend a Hole in a Cotton Blanket: 4 단계, 이미지 1개 중 1개
    • On the last you pull, do not pull all the way for it creates a loop. Put your needle through the loop, pull the thread all the way and this creates a secure knot.
  5. How to Mend a Hole in a Cotton Blanket: 5 단계, 이미지 3개 중 1개 How to Mend a Hole in a Cotton Blanket: 5 단계, 이미지 3개 중 2개 How to Mend a Hole in a Cotton Blanket: 5 단계, 이미지 3개 중 3개
    • Pick one side of the hole and go through to the other side while picking up fabric from the other side and pull our thread through all the way.
  6. How to Mend a Hole in a Cotton Blanket: 6 단계, 이미지 1개 중 1개
    • Repeat step 5 going in an upward direction until you have reached the top of the hole.
  7. How to Mend a Hole in a Cotton Blanket: 7 단계, 이미지 1개 중 1개
    • The last thread you pull through, do not pull all the way but instead put your need through the loop it creates and create a secure knot. Repeat this step about 2-3 more times threading through the same hole to create an extra secure knot.
  8. How to Mend a Hole in a Cotton Blanket: 8 단계, 이미지 1개 중 1개
    • Snip off the thread and make sure the hole has been mended. You can clean it up by trimming any loose fabric.
결승점
작성자
1다른 기여자 명과 함께
Kiara Lee
회원 가입일: 09/11/21
157 평판
안내서 1개를 작성함
York University, Team E-10, Melo-Thaiss Fall 2021 York University, Team E-10, Melo-Thaiss Fall 2021 회원
YORK-MELO-THAISS-F21SEG10
1 회원
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 26
지난 30일: 160
전체 시간: 6,841
