주요 콘텐츠로 건너뛰기
How to Mend a Hole in a Fuzzy Blanket
필요한 것
  1. How to Mend a Hole in a Fuzzy Blanket, How to Mend a Hole in a Fuzzy Blanket: 1 단계, 이미지 1개 중 1개
    • Pull the thread through the eye of the needle.
    • A good rule of thumb on how much thread to use is twice the size of the hole plus five inches for good measure.
    • Ensure there is 2 inches of thread going through the needle. This thread is used to tie off the knot at the end of the mend.
  2. How to Mend a Hole in a Fuzzy Blanket: 2 단계, 이미지 1개 중 1개
    • Place the fabric on the darning mushroom with the hole at the top of the mushroom.
    • Do not stretch the fabric. Stretching can distort the fabric edges permanently.
  3. How to Mend a Hole in a Fuzzy Blanket: 3 단계, 이미지 1개 중 1개
    • Find a starting place for the stitch.
    • A good place to start is at a sharp tear in the fabric.
    • Position the starting place so that it is furthest from you.
  4. How to Mend a Hole in a Fuzzy Blanket: 4 단계, 이미지 1개 중 1개
    • Pull the needle from under the fabric through the top of the hole.
    • Be sure that the stitch is not too close to the edge of the hole or else your stitch will come undone.
    • Also be sure that your stitch is not far away. This will make the mend more obvious.
  5. How to Mend a Hole in a Fuzzy Blanket: 5 단계, 이미지 1개 중 1개
    • Moving the needle through the hole, pull the needle from under the fabric just under and to the left or right of the previous stitch.
  6. How to Mend a Hole in a Fuzzy Blanket: 6 단계, 이미지 1개 중 1개
    • Continue working the stitch until the hole is mended.
  7. How to Mend a Hole in a Fuzzy Blanket: 7 단계, 이미지 1개 중 1개
    • Using the remaining thread and the thread that exists at the start of the stitch, tie a square knot.
    • This ensures that the stitch will not come undone.
  8. How to Mend a Hole in a Fuzzy Blanket: 8 단계, 이미지 1개 중 1개
    • Massage the knot so that it becomes uniform with the fabric.
    • Although fleece is thick, this will help the stitch blend in a little more.
결론
After following these instructions, your blanket should be just as functional as when you first got it. The mend is not too noticeable with especially thicker blankets, but may be noticeable in your project. With time and practice, this process can be done quickly and efficiently. If you need to undo the stitching for whatever reason, use the fabric scissors to cut the knot and gently pull the stitching in reverse order.
작성자
3다른 기여자 명과 함께
Amber Paschall
회원 가입일: 02/24/21
157 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 39
전체 시간: 4,019
