주요 콘텐츠로 건너뛰기
How to Mend a Snapped Elastic
필요한 것
  1. How to Mend a Snapped Elastic, Snapped Elastic: 1 단계, 이미지 1개 중 1개
    • Secure one piece of the elastic.
    • A piece of tape or a heavy object, like a book, are both great options.
  2. How to Mend a Snapped Elastic: 2 단계, 이미지 1개 중 1개
    • Thread the needle with your desired thread.
    • Tie the thread off at both ends.
  3. How to Mend a Snapped Elastic: 3 단계, 이미지 2개 중 1개 How to Mend a Snapped Elastic: 3 단계, 이미지 2개 중 2개
    • Poke the needle through the back side of your elastic.
    • Thread all of the thread through.
    • Be cautious of where the needle is at all times!
  4. How to Mend a Snapped Elastic: 4 단계, 이미지 2개 중 1개 How to Mend a Snapped Elastic: 4 단계, 이미지 2개 중 2개
    • Continue to thread the needle through, securing the elastic together.
    • Keep track of which side you want to be the back and which side will be the front.
  5. How to Mend a Snapped Elastic: 5 단계, 이미지 2개 중 1개 How to Mend a Snapped Elastic: 5 단계, 이미지 2개 중 2개
    • Experiment with different designs to secure the pieces together.
    • Use same-colored thread and simple lines to achieve a concealed repair, or use a colorful thread and a fun shape for a statement.
  6. How to Mend a Snapped Elastic: 6 단계, 이미지 1개 중 1개
    • Once the elastic is secure, finish the thread by snipping off the excess and tying the end into a knot.
  7. How to Mend a Snapped Elastic: 7 단계, 이미지 1개 중 1개
    • Secure the end of the thread with glue if desired.
    • If you choose to complete this step, check the glue's cure time. Wait until this cure time is over to proceed to the next step.
  8. How to Mend a Snapped Elastic: 8 단계, 이미지 1개 중 1개
    • Test the elastic to make sure it is secure.
결론
Show off your newly repaired elastic with pride!
작성자
1다른 기여자 명과 함께
Claire Jones
회원 가입일: 09/19/24
157 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 41
전체 시간: 342
