주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Modify Cliff Sensors so they never signal a cliff
필요한 것
  1. How to Modify Cliff Sensors so they never signal a cliff, Disassemble the sensor Clean or Continue: 2 단계, 이미지 2개 중 1개 How to Modify Cliff Sensors so they never signal a cliff, Disassemble the sensor Clean or Continue: 2 단계, 이미지 2개 중 2개
    • The sensor is easily disassembled by lifting the two small plastic latches on the side. Once the cover is removed you could clean the sensor and replace it....
    • Since I'm very tired of Error-6 messages and will not be adding stairs to my dirty house I opted to alter the sensor so that it will never detect a cliff falsely or otherwise.
    • These sensors work by emitting an IR light from one side and since there are baffles in the sensor it must bounce off a floor to reach the detector in the other side.
  2. How to Modify Cliff Sensors so they never signal a cliff: 3 단계, 이미지 2개 중 1개 How to Modify Cliff Sensors so they never signal a cliff: 3 단계, 이미지 2개 중 2개
    • THIS STEP CANNOT BE UNDONE.
    • I removed the baffles from the sensor so that the detector and emitter have a direct line of sight to each other
    • I used a small pair of wire cutters to cut out the baffles as needed
    • I put the Roomba back together and it cleaned until the battery was dead... For the first time in months...
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
David Miller Lowe
회원 가입일: 12/22/20
136 평판
안내서 1개를 작성함
3가이드 댓글
Thanks a lot David
هشام عادل إبراهيم - 답글 공유
Did this, but still get “ move rooms to a new location and press start!
Gary Stevens - 답글 공유
I had been using aluminum foil raped to the detectors, but this seems like a better approach. My foil would get worn or dislodged occasionally.
Joe McDaniel - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 13
지난 7일: 69
지난 30일: 329
전체 시간: 9,008
