주요 콘텐츠로 건너뛰기
How to Open Logitech Harmony 1100
필요한 것
  1. How to Open Logitech Harmony 1100, How to Open Logitech Harmony 1100: 1 단계, 이미지 1/2 How to Open Logitech Harmony 1100, How to Open Logitech Harmony 1100: 1 단계, 이미지 2/2
    • Remove battery cover, pushing down on circled areas and pushing outward
    • Remove battery by lifting up on corner exposed by indent in case
  2. How to Open Logitech Harmony 1100: 2 단계, 이미지 1/1
    • Use a J0 screwdriver head
    • Remove 3 screws from battery compartment
  3. How to Open Logitech Harmony 1100: 3 단계, 이미지 1/2 How to Open Logitech Harmony 1100: 3 단계, 이미지 2/2
    • Open connector port on side
    • Remove screw with PH00 screwdriver head
  4. How to Open Logitech Harmony 1100: 4 단계, 이미지 1/3 How to Open Logitech Harmony 1100: 4 단계, 이미지 2/3 How to Open Logitech Harmony 1100: 4 단계, 이미지 3/3
    • Use plastic opening tool to pry at the open slits on the side.
    • One or two silver foam cubes may pop out of the device. These belong in the slots shown in the third picture. They do not need to go back until reassembly.
    • Also the plastic connector door will fall off. It will need to be put back upon reassembly.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Keegan Williams
회원 가입일: 02/19/16
216 평판
안내서 2개 작성하였습니다
Ohio State, Team 1-5, Garvin Spring 2016 Ohio State, Team 1-5, Garvin Spring 2016 회원
OSU-GARVIN-S16S1G5
3 회원들
안내서 3개 작성하였습니다
댓글 한 개
Will changing the battery reset the settings within the remote?
wiboman AT gmail DOT com
Wibo Lammerts - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 19
전체 시간: 1,365
