주요 콘텐츠로 건너뛰기
How to Open Logitech Harmony 1100
필요한 것
  1. How to Open Logitech Harmony 1100, How to Open Logitech Harmony 1100: 1 단계, 이미지 2개 중 1개 How to Open Logitech Harmony 1100, How to Open Logitech Harmony 1100: 1 단계, 이미지 2개 중 2개
    • Remove the battery cover by pushing down on the circled areas and pushing outward.
    • Remove the battery by lifting up the battery on the corner exposed by the indent in the case
  2. How to Open Logitech Harmony 1100: 2 단계, 이미지 1개 중 1개
    • Use a J0 screwdriver head
    • Remove the 3 screws from battery compartment
  3. How to Open Logitech Harmony 1100: 3 단계, 이미지 2개 중 1개 How to Open Logitech Harmony 1100: 3 단계, 이미지 2개 중 2개
    • Open the connector port on the side.
    • Remove screw with a PH00 screwdriver head.
  4. How to Open Logitech Harmony 1100: 4 단계, 이미지 3개 중 1개 How to Open Logitech Harmony 1100: 4 단계, 이미지 3개 중 2개 How to Open Logitech Harmony 1100: 4 단계, 이미지 3개 중 3개
    • Use plastic opening tool to pry at the open slits on the side.
    • One or two silver foam cubes may pop out of the device. These belong in the slots shown in the third picture. They do not need to go back until reassembly.
    • The plastic connector door will fall off. It will need to be put back upon reassembly.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Keegan Williams
회원 가입일: 02/19/16
216 평판
안내서 2개를 작성함
Ohio State, Team 1-5, Garvin Spring 2016 Ohio State, Team 1-5, Garvin Spring 2016 회원
OSU-GARVIN-S16S1G5
3 회원들
안내서 3개를 작성함
1가이드 댓글
Will changing the battery reset the settings within the remote?
wiboman AT gmail DOT com
Wibo Lammerts - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 6
전체 시간: 1,558
