소개
Use this guide to open the Apple TV 4K 2021 Siri Remote for repairs.
필요한 것
Use a P2 Pentalobe screwdriver to remove the two 6.1 mm-long screws securing the bottom cover.
Remove the bottom aluminium cover.
Insert an iFlex into the gap on the right side of the circular clickpad.
Use the iFlex to create a gap by prying the circular clickpad upwards.
Insert an opening pick into the gap. Remove the iFlex after inserting the opening pick.
Slide the opening pick around the top half of the clickpad.
Lift the clickpad from the lower right side to access the press connector.
Use an opening pick to pry up the clickpad connector to disconnect it.
Remove the clickpad.
Insert the iFlex into the gap on the right edge of the volume button.
Insert the iFlex about 3 mm.
Use the iFlex to pry up the volume button to unhinge the plastic clips which keep the button in place.
Remove the volume button.
Use a T3 Torx screwdriver to remove the two 4.7 mm-long screws securing the Siri button on the right edge of the remote.
Turn the remote upside down.
Insert the flat end of a spudger into the charging port.
Push the spudger in to slide the insides of the remote out about 1 inch (2.5 cm).
Turn the remote back over and make sure that the recess of the inner frame aligns with the power button.
Use the pointed end of a spudger to press the power button into the recess of the inner frame (if it didn’t already fall in by itself).
Remove the power button.
Pull the inner frame out of its aluminum housing.
Repair didn’t go as planned? Check out our Answers community for help.
다른 7명이 해당 안내서를 완성하였습니다.
댓글 8개
Hi,
Thank you so much for the guide - I was able to open up my coffee spilled on remote clean it and actually fix it! However...somewhere along the lines I broke the Siri button (it was working fine prior to me opening up the remote)! It's a physical problem - I can't push it down physically, there is no spring like behavior...was there something in between the button that I dislodged? Any ideas?
Loosen the screws under the clickwheel and place the button a bit farther inwards.
Bachsau -
May not be immediately clear from the photos, but to extract the two P2 Pentalobe screws, you'll need to hold the P2 bit about 10-degrees off-axis. The screws are not longitudinal to the case.
I found the screw heads to be extremely brittle, got them out once and inserted again but now I am seeing small shavings coming off and can't open it again, word of caution
Ryan Owens - 답글
