주요 콘텐츠로 건너뛰기
How to Open the Huawei Watch GT 2 (42 mm)
필요한 것
  1. How to Open the Huawei Watch GT 2 (42 mm), Remove the watch band: 1 단계, 이미지 1/1
    • Before starting the repairs, take your watch off the charger and power it down.
    • Remove the watch band.
  2. How to Open the Huawei Watch GT 2 (42 mm), Unfasten the screws: 2 단계, 이미지 1/1
    • Use a T2 Torx screwdriver to remove the four 3.6 mm screws securing the back cover assembly.
  3. How to Open the Huawei Watch GT 2 (42 mm), Pry up the back cover assembly: 3 단계, 이미지 1/3 How to Open the Huawei Watch GT 2 (42 mm), Pry up the back cover assembly: 3 단계, 이미지 2/3 How to Open the Huawei Watch GT 2 (42 mm), Pry up the back cover assembly: 3 단계, 이미지 3/3
    • Insert an opening tool in the seam on the top edge between the back cover assembly and the watch case.
    • Use the opening tool to pry up the back cover assembly of your Huawei Watch GT 2 (42 mm).
    • Don't fully remove the back cover assembly just yet. It's still connected to the motherboard.
  4. How to Open the Huawei Watch GT 2 (42 mm), Lift the back cover assembly: 4 단계, 이미지 1/2 How to Open the Huawei Watch GT 2 (42 mm), Lift the back cover assembly: 4 단계, 이미지 2/2
    • Carefully swing the back cover assembly open to an upward position.
결론
To reassemble your Huawei Watch GT 2 (42 mm), follow these instructions in reverse order.
Opening didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for troubleshooting help.
Adriana Zwink
회원 가입일: 12/18/19
48,810 평판
안내서 167개 작성하였습니다
iFixit iFixit 회원
Staff
136 회원들
안내서 17,439개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 34
30일 전: 105
전체 시간: 3,108
