주요 콘텐츠로 건너뛰기
How to Open the Left Handle of the Backbone One
필요한 것
  1. How to Open the Left Handle of the Backbone One, Unfasten the screws: 1 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the four 5.9 mm-long screws.
  2. How to Open the Left Handle of the Backbone One, Rotate the upper cover: 2 단계, 이미지 3개 중 1개 How to Open the Left Handle of the Backbone One, Rotate the upper cover: 2 단계, 이미지 3개 중 2개 How to Open the Left Handle of the Backbone One, Rotate the upper cover: 2 단계, 이미지 3개 중 3개
    • Lift up the upper part of the controller.
    • Swing over the upper cover and place it on the controller case.
    • Take care that the interconnecting cable has no tension.
  3. How to Open the Left Handle of the Backbone One, Remove the protective tape: 3 단계, 이미지 3개 중 1개 How to Open the Left Handle of the Backbone One, Remove the protective tape: 3 단계, 이미지 3개 중 2개 How to Open the Left Handle of the Backbone One, Remove the protective tape: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to remove the yellow protective tape which is placed over the interconnect cable connector.
  4. How to Open the Left Handle of the Backbone One, Open the ZIF connector: 4 단계, 이미지 2개 중 1개 How to Open the Left Handle of the Backbone One, Open the ZIF connector: 4 단계, 이미지 2개 중 2개
    • Use the tip of an opening pick to open the gray flap of the ZIF connector by pushing it upwards.
  5. How to Open the Left Handle of the Backbone One, Disconnect the interconnect cable: 5 단계, 이미지 2개 중 1개 How to Open the Left Handle of the Backbone One, Disconnect the interconnect cable: 5 단계, 이미지 2개 중 2개
    • Use your fingers to disconnect the interconnect cable from its connector.
  6. How to Open the Left Handle of the Backbone One: 6 단계, 이미지 2개 중 1개 How to Open the Left Handle of the Backbone One: 6 단계, 이미지 2개 중 2개
    • Remove the upper half of the left controller assembly.
결론
Opening didn’t go as planned? Answers community for help.
작성자
1다른 기여자 명과 함께
Adriana Zwink
회원 가입일: 12/18/19
62,346 평판
안내서 167개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,656개를 작성함
2가이드 댓글
Did this work for you?
Shawn Gallant - 답글
Shawn Gallant - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 33
전체 시간: 1,641
