소개
Use this guide to open a Logitech MX Ergo for cleaning or repair.
필요한 것
Before you begin, flip the mouse's power switch into the OFF position.
Use a Torx T6 screwdriver to remove the six 5.7 mm-long screws securing the two halves of the mouse together.
Insert a spudger into the hole on the bottom of the mouse, located under the trackball.
Use the spudger to push the trackball out of its recess.
Remove the trackball.
Insert an opening pick into the gap on the right side of the mouse.
Rotate the opening pick about 30 degrees to unhinge the plastic clip.
For better access, place the top half of the mouse to the left of the lower half of the mouse.
Use the pointed end of a spudger to gently lift the left side of the black sliding lock on the interconnect cable socket until it stops.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 3개
Thank you. It was quite a coincidence that I found this because I had just purchased that fix it repair tool kit. It was pretty handy that I had it all right here in front of me. Thanks again you made it easy.
Hi @martilynn, thank you for sharing your experience! We're glad that the guide was useful for your repair.
