소개
Use this guide to remove the back cover of the Samsung Galaxy Watch4.
필요한 것
Before starting repairs, take your watch off the charger and power it down.
Remove the watch band.
Use a Tri-point Y000 screwdriver to remove the four 4.0 mm-long screws.
Insert an opening tool into the seam between the back cover and the metal housing.
Twist the opening tool to create a gap.
Lay the watch face down.
Carefully swing open the back cover by folding the back cover to the opposite site of the created gap.
Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
댓글 3개
the glass broke on the back of my watch 4 and i have managed to get all the shards and seal out without damaging anything, but I am having trouble finding remplacement glass for the sensor in canada
Champy Ton - 답글
It just suddenly turned off and won't turn on it just vibrates in sequences, i don't know what to do.
Salim Juma - 답글
I am having a real tough time unscrewing the screws despite having the right screwdriver. It is like they are stuck on.
