주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Operate the Timer Relay Box
필요한 것
  1. How to Operate the Timer Relay Box, Power the box: 1 단계, 이미지 2개 중 1개 How to Operate the Timer Relay Box, Power the box: 1 단계, 이미지 2개 중 2개
    • Connect the box to the mains power using an IEC C13 cable (kettle cable)
    • Check the switch is turned on.
    • Wait a few seconds, the LED under the knob will hold green to indicate the system is operating.
  2. How to Operate the Timer Relay Box, Connect the button trigger: 2 단계, 이미지 1개 중 1개
    • Connect the button cable to the timer box, as shown.
  3. How to Operate the Timer Relay Box, Connect the equipment: 3 단계, 이미지 1개 중 1개
    • Connect the equipment you would like the box to switch on and off.
  4. How to Operate the Timer Relay Box, Set the box to calibration mode: 4 단계, 이미지 1개 중 1개
    • Turn the system off and on using the switch at the power input
    • Push and hold the rotary knob, while the system is being powered on. Release the knob when the LED is solid purple.
    • The LED will begin to flash blue when ready.
  5. How to Operate the Timer Relay Box, Set the trigger delay: 5 단계, 이미지 1개 중 1개
    • Turn the knob clockwise to increase the delay, and counter clockwise to decrease. The delay changes in 0.5 second increments.
    • Turn the knob until the desired delay is achieved.
    • Press the knob to set the delay. The LED will flash green when the delay has been saved.
  6. How to Operate the Timer Relay Box, Set the power delay: 6 단계, 이미지 1개 중 1개
  7. How to Operate the Timer Relay Box, Operate the Timer Box: 7 단계, 이미지 3개 중 1개 How to Operate the Timer Relay Box, Operate the Timer Box: 7 단계, 이미지 3개 중 2개 How to Operate the Timer Relay Box, Operate the Timer Box: 7 단계, 이미지 3개 중 3개
    • Once calibrated, the timer box will switch to operation mode.
    • The LED will hold green when the box is waiting to be triggered.
    • The Box can be triggered through the button wires, or the encoder button
    • Once triggered, the LED will turn amber for the initial delay
    • The LED will turn RED when the equipment is being powered.
    • The LED will return to green once the system is ready to be triggered again.
    • Cycle the power, and trigger the system to ensure the calibration has been saved.
결론
작성자
1다른 기여자 명과 함께
James Schreiber
회원 가입일: 02/10/22
230 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 27
전체 시간: 382
