주요 콘텐츠로 건너뛰기
How to Patch a Fabric Tear in a Sleeping Bag
필요한 것
  1. How to Patch a Fabric Tear in a Sleeping Bag, Identify the torn area: 1 단계, 이미지 3개 중 1개 How to Patch a Fabric Tear in a Sleeping Bag, Identify the torn area: 1 단계, 이미지 3개 중 2개 How to Patch a Fabric Tear in a Sleeping Bag, Identify the torn area: 1 단계, 이미지 3개 중 3개
    • Lay the sleeping bag on a flat and clean space.
    • Locate the torn area, and clean away any lose pieces of stuffing or down.
    • Prepare the sleeping bag for repair, by putting the broken area in the middle of your work space.
  2. How to Patch a Fabric Tear in a Sleeping Bag, Prepare the Replacement Patch: 2 단계, 이미지 3개 중 1개 How to Patch a Fabric Tear in a Sleeping Bag, Prepare the Replacement Patch: 2 단계, 이미지 3개 중 2개 How to Patch a Fabric Tear in a Sleeping Bag, Prepare the Replacement Patch: 2 단계, 이미지 3개 중 3개
    • Prepare the self-adhesive patch.
    • Ensure that the repair patch is large enough to cover the hole. As an approximate guide, the patch should be 10mm wider than the hole on all sides, but the bigger the patch, the better. It may be tempting to cut the patch into a small size, but this is normally not recommended.
    • Start to peel away on the corner of the patch to be prepared for the next step.
  3. How to Patch a Fabric Tear in a Sleeping Bag, Stick the patch over the hole: 3 단계, 이미지 3개 중 1개 How to Patch a Fabric Tear in a Sleeping Bag, Stick the patch over the hole: 3 단계, 이미지 3개 중 2개 How to Patch a Fabric Tear in a Sleeping Bag, Stick the patch over the hole: 3 단계, 이미지 3개 중 3개
    • Note: this step is much easier with two people!
    • Flatten the area around the hole by pulling the material to each side, and pushing down on the stuffing. The goal is to make this area as flat and smooth as possible, and with the tear hole as closed as possible.
    • Tip: when flattening, down/stuffing may come out. Make sure to remove this from the repair area before attaching the patch.
    • While one person keeps the area flat, the other person places the first side of the patch onto the sleeping bag. Keeping even pressure and with a slow and careful movement, peel off the backing paper at the same time as pressing the patch onto the product. This is very similar to applying a first-aid plaster.
    • When the patch is fully applied, smooth out any wrinkles or bubbles with the back of your nail. The goal is to have a fully flat patch, with no creases or spaces for dust to get in, or down/stuffing to leak out.
  4. How to Patch a Fabric Tear in a Sleeping Bag, Finished and ready!: 4 단계, 이미지 2개 중 1개 How to Patch a Fabric Tear in a Sleeping Bag, Finished and ready!: 4 단계, 이미지 2개 중 2개
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
결론
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
작성자
1다른 기여자 명과 함께
Ben Blischke
회원 가입일: 07/19/23
10,230 평판
안내서 66개를 작성함
INTERSPORT INTERSPORT 회원
Community
25 회원들
안내서 169개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 31
전체 시간: 664
