주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Patch a Hole in Damaged Carpet
필요한 것
    1. How to Patch a Hole in Damaged Carpet, Hole in Carpet: 1 단계, 이미지 3개 중 1개 How to Patch a Hole in Damaged Carpet, Hole in Carpet: 1 단계, 이미지 3개 중 2개 How to Patch a Hole in Damaged Carpet, Hole in Carpet: 1 단계, 이미지 3개 중 3개
      • Place a can over the hole.
      • The can should completely cover the hole.
      댓글 쓰기
    2. How to Patch a Hole in Damaged Carpet: 2 단계, 이미지 3개 중 1개 How to Patch a Hole in Damaged Carpet: 2 단계, 이미지 3개 중 2개 How to Patch a Hole in Damaged Carpet: 2 단계, 이미지 3개 중 3개
      • Press down firmly on the can.
      • Cut around the can with a utility knife.
      • Utility knives are sharp, so handle with care.
      • Only cut through the carpet. Do not cut through the carpet pad underneath.
      댓글 쓰기
    3. How to Patch a Hole in Damaged Carpet: 3 단계, 이미지 3개 중 1개 How to Patch a Hole in Damaged Carpet: 3 단계, 이미지 3개 중 2개 How to Patch a Hole in Damaged Carpet: 3 단계, 이미지 3개 중 3개
      • Remove the can.
      • Lift out the old carpet.
      댓글 쓰기
    4. How to Patch a Hole in Damaged Carpet: 4 단계, 이미지 3개 중 1개 How to Patch a Hole in Damaged Carpet: 4 단계, 이미지 3개 중 2개 How to Patch a Hole in Damaged Carpet: 4 단계, 이미지 3개 중 3개
      • Flip sample carpet onto its back and place down on a stable surface.
      • Place the can onto the sample carpet.
      • Trace the shape of the can with a marker.
      댓글 쓰기
    5. How to Patch a Hole in Damaged Carpet: 5 단계, 이미지 3개 중 1개 How to Patch a Hole in Damaged Carpet: 5 단계, 이미지 3개 중 2개 How to Patch a Hole in Damaged Carpet: 5 단계, 이미지 3개 중 3개
      • Remove the can from the sample carpet.
      • Cut out the shape from the sample carpet using scissors.
      • Kitchen scissors are sharp. Always cut away from yourself.
      댓글 쓰기
    6. How to Patch a Hole in Damaged Carpet: 6 단계, 이미지 3개 중 1개 How to Patch a Hole in Damaged Carpet: 6 단계, 이미지 3개 중 2개 How to Patch a Hole in Damaged Carpet: 6 단계, 이미지 3개 중 3개
      • Check to make sure the replacement piece of carpet fits into the hole.
      • If necessary, trim sample to fit or cut another piece.
      댓글 쓰기
    7. How to Patch a Hole in Damaged Carpet: 7 단계, 이미지 2개 중 1개 How to Patch a Hole in Damaged Carpet: 7 단계, 이미지 2개 중 2개
      • Evenly spread glue on the underside of the replacement carpet.
      • The carpet should be placed down before the glue dries.
      댓글 쓰기
    8. How to Patch a Hole in Damaged Carpet: 8 단계, 이미지 2개 중 1개 How to Patch a Hole in Damaged Carpet: 8 단계, 이미지 2개 중 2개
      • Place the glue side of the carpet down into the hole.
      • Press down firmly on the carpet with your hand.
      • Let glue dry before using the carpet.
      댓글 쓰기
    9. How to Patch a Hole in Damaged Carpet: 9 단계, 이미지 2개 중 1개 How to Patch a Hole in Damaged Carpet: 9 단계, 이미지 2개 중 2개
      • Trim carpet fibers to blend the replacement carpet with the original.
      댓글 쓰기
결론
Once the glue has dried the carpet can be walked on or vacuumed. By cutting the longer carpet fibers the replacement patch should seamlessly blend in with the original carpet.
취소: 해당 안내서를 완성하지 않았습니다.
다른 8명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Kaleigh Smith
회원 가입일: 01/16/20
385 평판
안내서 1개를 작성함
2가이드 댓글
Very good. I suppose if you don't have same carpet you can match as close as possible with a new piece.
Brian Taylor - 답글 공유
Excellent tip - thank you for sharing!!
Rama Narsing - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 43
지난 30일: 289
전체 시간: 29,466
