주요 콘텐츠로 건너뛰기
How to Patch a Hole in Jeans with Wool
필요한 것
  1. How to Patch a Hole in Jeans with Wool, Patching a hole in Jean: 1 단계, 이미지 1/3 How to Patch a Hole in Jeans with Wool, Patching a hole in Jean: 1 단계, 이미지 2/3 How to Patch a Hole in Jeans with Wool, Patching a hole in Jean: 1 단계, 이미지 3/3
    • Cut a piece of felt large enough to cover the hole
  2. How to Patch a Hole in Jeans with Wool: 2 단계, 이미지 1/2 How to Patch a Hole in Jeans with Wool: 2 단계, 이미지 2/2
    • Insert thread through the needle hole.
  3. How to Patch a Hole in Jeans with Wool: 3 단계, 이미지 1/3 How to Patch a Hole in Jeans with Wool: 3 단계, 이미지 2/3 How to Patch a Hole in Jeans with Wool: 3 단계, 이미지 3/3
    • Make a loop at the end of the thread.
    • Pull the end of the thread through the loop creating a knot.
  4. How to Patch a Hole in Jeans with Wool: 4 단계, 이미지 1/3 How to Patch a Hole in Jeans with Wool: 4 단계, 이미지 2/3 How to Patch a Hole in Jeans with Wool: 4 단계, 이미지 3/3
    • Grab the end of the jean with your hand.
    • Pull the jean towards you, making it inside out.
    • Place the felt on the hole.
  5. How to Patch a Hole in Jeans with Wool: 5 단계, 이미지 1/3 How to Patch a Hole in Jeans with Wool: 5 단계, 이미지 2/3 How to Patch a Hole in Jeans with Wool: 5 단계, 이미지 3/3
    • Pinch together the jean and the felt.
    • Insert the needle horizontally into the jean and edge of the felt.
    • Pull the needle through till the knot touches the felt.
    • Repeat the above steps until the border of the felt is stitched.
    • Make a knot at the end.
    • Cut off excess thread.
  6. How to Patch a Hole in Jeans with Wool: 6 단계, 이미지 1/3 How to Patch a Hole in Jeans with Wool: 6 단계, 이미지 2/3 How to Patch a Hole in Jeans with Wool: 6 단계, 이미지 3/3
    • Grasp the end of the jeans and pull them towards you to turn them right side out.
    • Insert the foam board into the pants and position it underneath the hole.
  7. How to Patch a Hole in Jeans with Wool: 7 단계, 이미지 1/3 How to Patch a Hole in Jeans with Wool: 7 단계, 이미지 2/3 How to Patch a Hole in Jeans with Wool: 7 단계, 이미지 3/3
    • Grab more than enough wool to cover the size of your hole, ensuring it is at least an inch thick.
    • Rub the wool between hands to make a ball.
    • Place the wool on top of the hole.
  8. How to Patch a Hole in Jeans with Wool: 8 단계, 이미지 1/3 How to Patch a Hole in Jeans with Wool: 8 단계, 이미지 2/3 How to Patch a Hole in Jeans with Wool: 8 단계, 이미지 3/3
    • Stab the wool through the jean and onto the foam board.
    • Repeat until the wool is hardened.
  9. How to Patch a Hole in Jeans with Wool: 9 단계, 이미지 1/3 How to Patch a Hole in Jeans with Wool: 9 단계, 이미지 2/3 How to Patch a Hole in Jeans with Wool: 9 단계, 이미지 3/3
    • Rub some soap onto the wool to tangle the fibers.
    • Place the jeans into the laundry machine.
    • Wash on cold and air dry.
    • Wear your cute mended pants!
결승점
LiTong Liu
회원 가입일: 04/25/24
169 평판
안내서 1개 작성함
UC Davis, Team 1-2, Whithaus Spring 2024 UC Davis, Team 1-2, Whithaus Spring 2024 회원
UCD-WHITHAUS-S24S1G2
3 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 19
30일 전: 108
전체 시간: 162
