주요 콘텐츠로 건너뛰기
How to Patch a Hole in a Kote
필요한 것
  1. How to Patch a Hole in a Kote, How to Patch a Hole in a Kote: 1 단계, 이미지 1개 중 1개
    • Use the ruler to measure the hole, and add a 1/4 to 1/2 inch buffer on all sides.
  2. How to Patch a Hole in a Kote: 2 단계, 이미지 1개 중 1개
    • Use the ruler and pen to create guiding lines for these measurements directly on the backside of the leather patch.
  3. How to Patch a Hole in a Kote: 3 단계, 이미지 1개 중 1개
    • Use the scissors to cut along the guiding lines.
  4. How to Patch a Hole in a Kote: 4 단계, 이미지 1개 중 1개
    • Center the leather patch over the hole and pin it in place.
  5. How to Patch a Hole in a Kote: 5 단계, 이미지 1개 중 1개
    • Cut approximately 30 inches of thread and thread 15 inches through the needle.
    • Tie the two ends of the thread into a square knot by creating a loop, drawing the ends through the loop, and pulling it tight.
  6. How to Patch a Hole in a Kote: 6 단계, 이미지 2개 중 1개 How to Patch a Hole in a Kote: 6 단계, 이미지 2개 중 2개
    • After drawing the thread through the patch from below, about 1/4 inch from the edge, use the thimble to push the needle through the kote, just outside the patch.
    • Use the pliers to pull the needle through the kote and leather.
    • Repeat the process all around the patch until you return to the first stitch.
  7. How to Patch a Hole in a Kote: 7 단계, 이미지 3개 중 1개 How to Patch a Hole in a Kote: 7 단계, 이미지 3개 중 2개 How to Patch a Hole in a Kote: 7 단계, 이미지 3개 중 3개
    • Knot the final stitch in place by running the needle under the first stitch.
    • Pull the thread to create a loop, and run the needle through the loop towards you.
    • To hide the knot, run the needle beneath the patch and pull the thread through, cutting it close to the patch.
  8. How to Patch a Hole in a Kote: 8 단계, 이미지 1개 중 1개
    • You have successfully patched the hole in your kote.
결론
To patch your kote, follow these steps in chronological order.
작성자
1다른 기여자 명과 함께
Dawn Lattin
회원 가입일: 06/11/21
157 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 30
전체 시간: 1,259
