주요 콘텐츠로 건너뛰기
How to Patch a Hole on a Stuffed Toy
필요한 것
  1. How to Patch a Hole on a Stuffed Toy, How to Patch a Hole on a Stuffed Toy: 1 단계, 이미지 1개 중 1개
    • Start by ensuring the stuffed toy is clean and free of any loose debris.
  2. How to Patch a Hole on a Stuffed Toy: 2 단계, 이미지 3개 중 1개 How to Patch a Hole on a Stuffed Toy: 2 단계, 이미지 3개 중 2개 How to Patch a Hole on a Stuffed Toy: 2 단계, 이미지 3개 중 3개
    • Cut a piece of fabric that's large enough to cover the hole with some extra space for sewing.
    • The patch should be a little bigger than the hole.
  3. How to Patch a Hole on a Stuffed Toy: 3 단계, 이미지 1개 중 1개
    • Place the patch over the hole on the outside of the stuffed toy, aligning it as closely as possible with the surrounding fabric.
  4. How to Patch a Hole on a Stuffed Toy: 4 단계, 이미지 2개 중 1개 How to Patch a Hole on a Stuffed Toy: 4 단계, 이미지 2개 중 2개
    • Thread your needle and tie a knot at the end.
    • Use a length of thread about 18 inches.
  5. How to Patch a Hole on a Stuffed Toy: 5 단계, 이미지 2개 중 1개 How to Patch a Hole on a Stuffed Toy: 5 단계, 이미지 2개 중 2개
    • Starting from the inside of the stuffed toy, push the needle in the fabric of the toy and then pull through.
    • Leave a small tail of thread inside the hole.
  6. How to Patch a Hole on a Stuffed Toy: 6 단계, 이미지 1개 중 1개
    • Using a simple running stitch, sew around the edge of the patch, securing it to the toy.
    • Make sure your stitches are close together and evenly spaced for a secure hold.
  7. How to Patch a Hole on a Stuffed Toy: 7 단계, 이미지 2개 중 1개 How to Patch a Hole on a Stuffed Toy: 7 단계, 이미지 2개 중 2개
    • When you've sewn all the way around the patch, tie off your thread by making a knot close to the fabric.
    • You can do this by making a small loop with the thread and passing the needle through the loop before pulling it tight.
  8. How to Patch a Hole on a Stuffed Toy: 8 단계, 이미지 2개 중 1개 How to Patch a Hole on a Stuffed Toy: 8 단계, 이미지 2개 중 2개
    • Carefully trim any excess fabric from the patch and snip off any loose thread ends.
  9. How to Patch a Hole on a Stuffed Toy: 9 단계, 이미지 1개 중 1개
    • Give the repaired area a gentle tug to ensure the patch is securely attached.
    • Feel free to add an outline over the patch for a unique look.
  10. How to Patch a Hole on a Stuffed Toy: 10 단계, 이미지 1개 중 1개
    • Make sure there are no loose threads or fabric scraps on the toy.
    • Enjoy your repaired toy!
결론
Each stitch made represents a commitment to preserving the warmth, comfort, and nostalgia it brings into your life. Your mended toy is a symbol of your dedication to renewing connections and finding joy in simple yet profound ways. So, hold your restored friend close, and let it inspire you to navigate life with a heart full of warmth and an unwavering spirit of resilience.
다른 한 분이 해당 안내서를 완성하였습니다.
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 40
전체 시간: 659
