주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Patch a Ripped Backpack
필요한 것
  1. How to Patch a Ripped Backpack, Identify the repair area: 1 단계, 이미지 3개 중 1개 How to Patch a Ripped Backpack, Identify the repair area: 1 단계, 이미지 3개 중 2개 How to Patch a Ripped Backpack, Identify the repair area: 1 단계, 이미지 3개 중 3개
    • Identify the defective area and assess how large the damage is.
  2. How to Patch a Ripped Backpack, Prepare for patching: 2 단계, 이미지 3개 중 1개 How to Patch a Ripped Backpack, Prepare for patching: 2 단계, 이미지 3개 중 2개 How to Patch a Ripped Backpack, Prepare for patching: 2 단계, 이미지 3개 중 3개
    • Use a pair of scissors to cut the loose threads and clean the area.
    • Use a similar color fabric to create your "own patch".
    • Tip: Cut a piece of fabric that is at least 1cm bigger than the tear (from each side). Use a sewing machine to create a hem around the border of the patch.
  3. How to Patch a Ripped Backpack, Pin the area: 3 단계, 이미지 3개 중 1개 How to Patch a Ripped Backpack, Pin the area: 3 단계, 이미지 3개 중 2개 How to Patch a Ripped Backpack, Pin the area: 3 단계, 이미지 3개 중 3개
    • Use sewing pins to pin the area and set the patch in place.
    • Start sewing follow the shape of the patch.
  4. How to Patch a Ripped Backpack, Continue stitching: 4 단계, 이미지 3개 중 1개 How to Patch a Ripped Backpack, Continue stitching: 4 단계, 이미지 3개 중 2개 How to Patch a Ripped Backpack, Continue stitching: 4 단계, 이미지 3개 중 3개
    • Once you have stitched the first side of the patch. Apply more sewing pins to set the patch in place and continue sewing.
    • Tip: In this example, a square patch was used to repair the tear. For aesthetic reasons, a “triangle” shape was achieved by inserting part of the patch inside the tear and folding one side inward.
  5. How to Patch a Ripped Backpack, Finished and ready!: 5 단계, 이미지 3개 중 1개 How to Patch a Ripped Backpack, Finished and ready!: 5 단계, 이미지 3개 중 2개 How to Patch a Ripped Backpack, Finished and ready!: 5 단계, 이미지 3개 중 3개
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
결론
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
작성자
1다른 기여자 명과 함께
Ben Blischke
회원 가입일: 07/19/23
10,230 평판
안내서 68개를 작성함
INTERSPORT INTERSPORT 회원
Community
25 회원들
안내서 172개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 56
전체 시간: 814
