주요 콘텐츠로 건너뛰기
How to Patch a Small Hole in Drywall
필요한 것
  1. How to Patch a Small Hole in Drywall, How to Patch a Small Hole in Drywall: 1 단계, 이미지 3개 중 1개 How to Patch a Small Hole in Drywall, How to Patch a Small Hole in Drywall: 1 단계, 이미지 3개 중 2개 How to Patch a Small Hole in Drywall, How to Patch a Small Hole in Drywall: 1 단계, 이미지 3개 중 3개
    • If the initial hole is smaller than a quarter, use a screwdriver to carefully make the hole larger. This will allow the patching plaster to fill better.
    • Place painter's tape around the hole so the plaster does not get onto places it does not belong.
  2. How to Patch a Small Hole in Drywall: 2 단계, 이미지 3개 중 1개 How to Patch a Small Hole in Drywall: 2 단계, 이미지 3개 중 2개 How to Patch a Small Hole in Drywall: 2 단계, 이미지 3개 중 3개
    • Dip the chisel scraper into the patching plaster, and begin to fill the hole. Use a gentle pressing motion to fill. Press multiple layers of the plaster until the entire hole is filled.
    • Let the wall dry for at least three hours.
  3. How to Patch a Small Hole in Drywall: 3 단계, 이미지 2개 중 1개 How to Patch a Small Hole in Drywall: 3 단계, 이미지 2개 중 2개
    • After the filling is fully dry, take a damp sponge and gently remove any access plaster from the wall. First, start with the surface surrounding the hole.
    • After the wall is clean of excess plaster, carefully wipe the plaster from inside the wall until it is even with the original surface.
  4. How to Patch a Small Hole in Drywall: 4 단계, 이미지 3개 중 1개 How to Patch a Small Hole in Drywall: 4 단계, 이미지 3개 중 2개 How to Patch a Small Hole in Drywall: 4 단계, 이미지 3개 중 3개
    • Remove the painters tape from the wall.
    • Dip the paint sponge in paint, and paint the wall with the original color of the wall.
    • Let it dry accordingly.
결론
Hopefully you found this guide easy and helpful for fixing any minor dents in your drywall. Good luck!
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Jessica Yurgin
회원 가입일: 01/19/16
178 평판
안내서 1개를 작성함
Oakland University, Team 6-1, Walwema Winter 2016 Oakland University, Team 6-1, Walwema Winter 2016 회원
OAK-WALWEMA-W16S6G1
10 회원들
안내서 13개를 작성함
2가이드 댓글
Great guide to fixing plasterboard. I normally just try to fit a scrap piece of plasterboard in the hole when fixing it, but using cardboard is a much easier and better idea. I can cut it with scissors and won't have to make the whole bigger to screw the piece of drywall in. If you need help with drywall repair in your home visit: https://www.plasterroanoke.com
Kim - 답글
Very nice… I really like your blog. Very useful information.
Century Drywall - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 35
전체 시간: 5,846
