주요 콘텐츠로 건너뛰기
How to Patch a Tear in Vinyl Furniture
필요한 것
  1. How to Patch a Tear in Vinyl Furniture, How to Patch a Tear in Vinyl Furniture: 1 단계, 이미지 1개 중 1개
    • Clean the damaged area with rubbing alcohol, using a rag, paper towel, or Q-tip.
  2. How to Patch a Tear in Vinyl Furniture: 2 단계, 이미지 1개 중 1개
    • Cut the backing fabric large enough to cover the tear, approximately half an inch larger around the tear.
  3. How to Patch a Tear in Vinyl Furniture: 3 단계, 이미지 2개 중 1개 How to Patch a Tear in Vinyl Furniture: 3 단계, 이미지 2개 중 2개
    • Use the spatula tool to insert the backing fabric underneath the tear.
  4. How to Patch a Tear in Vinyl Furniture: 4 단계, 이미지 2개 중 1개 How to Patch a Tear in Vinyl Furniture: 4 단계, 이미지 2개 중 2개
    • Use the spatula to apply the adhesive to the damaged area.
    • Choose a color that matches your furniture. You may need to mix colors to acheive the correct shade.
  5. How to Patch a Tear in Vinyl Furniture: 5 단계, 이미지 1개 중 1개
    • Let the adhesive dry for approximately four hours.
    • You may use a hair dryer to speed up the drying process.
  6. How to Patch a Tear in Vinyl Furniture: 6 단계, 이미지 2개 중 1개 How to Patch a Tear in Vinyl Furniture: 6 단계, 이미지 2개 중 2개
    • Use a Q-tip dipped in rubbing alcohol to buff and blend the area.
    • Apply light pressure to even out the edges.
결론
Once the adhesive is dry, the furniture is ready for use!
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Bailey Arman
회원 가입일: 09/19/18
188 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 54
전체 시간: 27,321
