주요 콘텐츠로 건너뛰기
How to Patch a Tear in Vinyl Furniture
필요한 것
  1. How to Patch a Tear in Vinyl Furniture, How to Patch a Tear in Vinyl Furniture: 1 단계, 이미지 1/1
    • Clean the damaged area with rubbing alcohol, using a rag, paper towel, or Q-tip.
  2. How to Patch a Tear in Vinyl Furniture: 2 단계, 이미지 1/1
    • Cut the backing fabric large enough to cover the tear, approximately half an inch larger around the tear.
  3. How to Patch a Tear in Vinyl Furniture: 3 단계, 이미지 1/2 How to Patch a Tear in Vinyl Furniture: 3 단계, 이미지 2/2
    • Use the spatula tool to insert the backing fabric underneath the tear.
  4. How to Patch a Tear in Vinyl Furniture: 4 단계, 이미지 1/2 How to Patch a Tear in Vinyl Furniture: 4 단계, 이미지 2/2
    • Use the spatula to apply the adhesive to the damaged area.
    • Choose a color that matches your furniture. You may need to mix colors to acheive the correct shade.
  5. How to Patch a Tear in Vinyl Furniture: 5 단계, 이미지 1/1
    • Let the adhesive dry for approximately four hours.
    • You may use a hair dryer to speed up the drying process.
  6. How to Patch a Tear in Vinyl Furniture: 6 단계, 이미지 1/2 How to Patch a Tear in Vinyl Furniture: 6 단계, 이미지 2/2
    • Use a Q-tip dipped in rubbing alcohol to buff and blend the area.
    • Apply light pressure to even out the edges.
결론
Once the adhesive is dry, the furniture is ready for use!
다른 4명이 해당 안내서를 완성하였습니다.
Bailey Arman
회원 가입일: 09/19/18
188 평판
안내서 1개 작성함
University of Minnesota, Team S1-G4, Card Fall 2018 University of Minnesota, Team S1-G4, Card Fall 2018 회원
UMN-CARD-F18S1G4
3 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 95
30일 전: 381
전체 시간: 24,819
