주요 콘텐츠로 건너뛰기
How to Perform Circuit Service on the Newport HT70
의료 장비
iFixit과 이 수리 안내서는 의료 기기 제조업체가 보증하지 않으며 제휴 관계가 없습니다.
  1. How to Perform Circuit Service on the Newport HT70, Setup: 1 단계, 이미지 1/1
    • Connect the breathing circuit to the main flow outlet, or as if it were being used for a patient.
    • Cover up the breathing circuit (do not use test lung) .
  2. How to Perform Circuit Service on the Newport HT70, Begin Test: 2 단계, 이미지 1/1
    • Touch the Circuit Check button at the top of the screen.
    • Press ‘Accept’.
    • Uncover the end of the patient circuit pictured in Step 1.
    • Press the ‘Accept’ button to continue with the circuit check.
    • If test passes, the message “Circuit Check PASSED press accept to confirm” will appear on the screen.
    • If the Circuit check does not pass, do not use the ventilator for patient use. Use an alternate Method of ventilation.
    • If the Circuit Check has failed, there may be an issue with the pump assembly, refer to the “Pump Assembly Replacement” guide to proceed with this diagnosis.
결론
Merek McGill
회원 가입일: 04/07/20
520 평판
안내서 5개 작성하였습니다
Cal Poly, Team S7-G5, Paton Spring 2020 Cal Poly, Team S7-G5, Paton Spring 2020 회원
CPSU-PATON-S20S7G5
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 8
전체 시간: 325
