주요 콘텐츠로 건너뛰기
How to Perform a Hard Reset
필요한 것
  1. How to Perform a Hard Reset, Face Plate: 1 단계, 이미지 1/1
    • Press the eject button on the bottom left corner of the face plate.
  2. How to Perform a Hard Reset: 2 단계, 이미지 1/3 How to Perform a Hard Reset: 2 단계, 이미지 2/3 How to Perform a Hard Reset: 2 단계, 이미지 3/3
    • Begin by slightly lifting the face plate out from the side located by the release button.
    • Slide towards the side of the eject button, then completely lift out.
  3. How to Perform a Hard Reset, How to Perform a Hard Reset: 3 단계, 이미지 1/1
    • You will now have the face plate and the main component that includes the CD drive. Put the face plate aside and locate the small circle button labelled "Reset" on the main component.
    • Make sure the car power is on.
    • Press and hold the reset button with a pointed edge tool for 5 seconds.
결론
다른 10명이 해당 안내서를 완성하였습니다.
Connor Finley
회원 가입일: 02/18/17
857 평판
안내서 4개 작성하였습니다
USF Tampa, Team S2-G5, Lacy Spring 2017 USF Tampa, Team S2-G5, Lacy Spring 2017 회원
USFT-LACY-S17S2G5
4 회원들
안내서 11개 작성하였습니다
댓글 한 개
I have a Kenwood car stereo w4044ua and i put a code on it, will the code be removed when I reset ihe device
Defcon 1 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 14
7일 전: 89
30일 전: 416
전체 시간: 62,784
