주요 콘텐츠로 건너뛰기
How to Pick Up a Dropped Stitch in Knitting
필요한 것
  1. How to Pick Up a Dropped Stitch in Knitting, How to Pick Up a Dropped Stitch in Knitting: 1 단계, 이미지 1개 중 1개
    • Locate the dropped stitch.
    • A dropped stitch is a loop of unsecured yarn, which means that no yarn is going through the loop.
  2. How to Pick Up a Dropped Stitch in Knitting: 2 단계, 이미지 2개 중 1개 How to Pick Up a Dropped Stitch in Knitting: 2 단계, 이미지 2개 중 2개
    • Insert the left needle through the loop of the dropped stitch.
    • You may use the right needle to grab the dropped stitch, but the dropped stitch must end on the left needle.
  3. How to Pick Up a Dropped Stitch in Knitting: 3 단계, 이미지 1개 중 1개
    • Locate the bar of yarn behind the dropped stitch.
    • Depending on how many rows the stitch has unraveled, there may be multiple bars of yarn. If the stitch has unraveled more than one row, locate the bottom bar.
  4. How to Pick Up a Dropped Stitch in Knitting: 4 단계, 이미지 2개 중 1개 How to Pick Up a Dropped Stitch in Knitting: 4 단계, 이미지 2개 중 2개
    • Insert the right needle beneath the bottom bar of yarn and lift it onto the left needle.
  5. How to Pick Up a Dropped Stitch in Knitting: 5 단계, 이미지 2개 중 1개 How to Pick Up a Dropped Stitch in Knitting: 5 단계, 이미지 2개 중 2개
    • Use the tight needle to slip the dropped stitch over the bar of yarn.
  6. How to Pick Up a Dropped Stitch in Knitting: 6 단계, 이미지 3개 중 1개 How to Pick Up a Dropped Stitch in Knitting: 6 단계, 이미지 3개 중 2개 How to Pick Up a Dropped Stitch in Knitting: 6 단계, 이미지 3개 중 3개
    • Repeat steps 3-5 for each row that the dropped stitch has unraveled.
  7. How to Pick Up a Dropped Stitch in Knitting: 7 단계, 이미지 1개 중 1개
    • Once the dropped stitch has been picked up all the way to the current row, proceed in pattern.
결론
Your knitting project should now be fixed, and you can proceed with your work.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Jillian Garcia
회원 가입일: 09/28/22
202 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 20
지난 30일: 97
전체 시간: 893
