1. Find the power cord.
    • Find the power cord.
    • Make sure that it is unplugged from the outlet. This is to make sure that no power is flowing through and you are not injured.
  2. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  3. Check to make sure that the power cord is connected to the device. If it is not connect the smaller end to the back of the device.
    • Check to make sure that the power cord is connected to the device. If it is not connect the smaller end to the back of the device.
  4. Check to make sure that the power cord is connected to an outlet. If not, take the two-pronged end and plug it in to an outlet. The device is now correctly plugged in.
    • Check to make sure that the power cord is connected to an outlet. If not, take the two-pronged end and plug it in to an outlet. The device is now correctly plugged in.
결론
Rosana Cheruvelil
회원 가입일: 2012년 09월 26일
63 평판
안내서 3개 작성하였습니다
Cal Poly, Team 7-50, Forte Fall 2012 Cal Poly, Team 7-50, Forte Fall 2012 회원
CPSU-FORTE-F12S7G50
5 회원들
안내서 8개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 196
