주요 콘텐츠로 건너뛰기
How to Prevent a Run or Tear in Tights from Spreading
필요한 것
  1. How to Prevent a Run or Tear in Tights from Spreading, Run or Tear in Tights: 1 단계, 이미지 2개 중 1개 How to Prevent a Run or Tear in Tights from Spreading, Run or Tear in Tights: 1 단계, 이미지 2개 중 2개
    • Put the ripped tights on for easier repair, or leave them on if you’re already wearing them.
    • Gather clear nail polish and a pair of scissors.
  2. How to Prevent a Run or Tear in Tights from Spreading: 2 단계, 이미지 1개 중 1개
    • Locate all potential runs or directions that the rip can expand.
    • Runs will not usually expand horizontally, but be sure to check both vertical ends of the run.
  3. How to Prevent a Run or Tear in Tights from Spreading: 3 단계, 이미지 1개 중 1개
    • Gently tug the tights away from your skin to prevent the nail polish from affixing to your body.
  4. How to Prevent a Run or Tear in Tights from Spreading: 4 단계, 이미지 2개 중 1개 How to Prevent a Run or Tear in Tights from Spreading: 4 단계, 이미지 2개 중 2개
    • Brush a dollop of clear nail polish on all potential runs.
    • Small runs will require just a dab of nail polish while larger holes may require a thin coat.
    • Repeat these steps to all potential runs and loose threads.
  5. How to Prevent a Run or Tear in Tights from Spreading: 5 단계, 이미지 1개 중 1개
    • Once the nail polish has dried, you may cut any hanging pieces of thread.
    • The nail polish will take about 1 minute to dry.
    • Be sure to complete this step after applying the nail polish and letting it dry or a new run will form.
결론
These steps can save a pair of tights from becoming too tattered for normal use.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Audrey Fremier
회원 가입일: 02/23/15
261 평판
안내서 1개를 작성함
Cal Poly, Team 12-1, Green Winter 2015 Cal Poly, Team 12-1, Green Winter 2015 회원
CPSU-GREEN-W15S12G1
6 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 27
지난 30일: 138
전체 시간: 41,547
